As title suggests...my radiator fans arn't spinning at all and I need help...what can i do or what could be the problem (im guessing its something to do with electricals).
thanks in advance
Need help - Radiator fans not working!?
- JSE
- Craig
- Vehicle: Non MX-5
- StanTheMan
- JSE
- Garry
Unless your car has been modified the main fan will only come on when the coolant temperature gets to hot. The main fan and A/C fan also cycle on and off with the A/C compressor. Easiest way to check to see if the fans themselves are OK is to turn on the A/C with the engine running. The fans should start turning when the compressor clicks in.
- sabretooth
- Vehicle: NA8 - Turbo
