1.6 & 1.8 5 speed
Forced Fives
Vehicle: 10AE - Turbo
1.6 & 1.8 5 speed
Postby Forced Fives » Wed May 24, 2006 8:06 pm
Can anyone confirm that the 5 speed from a 1.8 bolt straight into a NA 1.6 without midification or are there differences between the gearboxes?
Are the NA & NB 5 speed also the same?
Thanks
10AE Turbo
Russellb
RIP Nov 2014
Postby Russellb » Wed May 24, 2006 8:14 pm
I think the NA 1.6 and 1.8 G'boxes are the same but I think the NB 5 and 6 Sp Boxes take a differant Starter motor I am sure that I will be corected if I'm wrong :oops:
My ClubmanRebuild
MX5 SE Rally car is HERE :)
kula
Postby kula » Wed May 24, 2006 9:22 pm
afaik that's true.
Roderic
Postby Roderic » Wed May 24, 2006 9:24 pm
Doesnt meam you still cant get a 6 Speed box into your NA ;)
Thanks to:
Alberts Car Stereo-Fabrication/Stereo
Imports 101-Compliance/Mechanical
Miata Mania-Various
MX5 Mania-04 NB Interior
MX5 Plus-Engine, Gearbox, Brakes, Diff
MX5 Parts.UK-Rear Tail Lights
Prestige Motorsport-Importing
Wheelspin-Mechanical
Russellb
RIP Nov 2014
Postby Russellb » Wed May 24, 2006 9:34 pm
I know now have a 6 sp in my old man's NA6 :D Just used two bolt instead of 3 to hold the starter in 8)
O and the NB box has a different Stick
My ClubmanRebuild
Roderic
Postby Roderic » Wed May 24, 2006 9:54 pm
Different stick?
Do you mean the screw threads are different? So a gear knob from a 5 speed wont fit onto a 6 speed?
Thanks to:
Miata Mania-Various
Russellb
RIP Nov 2014
Postby Russellb » Wed May 24, 2006 10:08 pm
NA 5 sp has single pin the NB 5 and 6 sp have 2 pins
Also some 6sp have a small ball end some have a big ball end
Hope this make sense it been a long day :?
Threads are the same
My ClubmanRebuild
Forced Fives
Postby Forced Fives » Wed May 24, 2006 11:22 pm
Thanks guys.
So any MX5 5 Speed box should bolt straight in ?
10AE Turbo
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu May 25, 2006 9:43 am
Any gearbox bolts straight in definately...
The 1.8 gearbox has double syncro on 2nd. gear...pretty much the only difference.
As Russel said the 6 speed bolts in but you just use 2 bolts on the starter or fit the later starter...the 6 speed has different wiring but thats easy to fix.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Jun 22, 2006 12:54 pm
lam.666 wrote:sorry to hijack, but my question is in relation to the na6 and na8 gearboxes.
which one would be more stronger?
apart from the 2nd synchro on the na8 are there any other differences?
where are the startor motors located?
and finally are the bell housings on the na6 and na8 gearboxes removable?
cheers guys
All 5 speeds about the same strength...double syncro just makes smoother gear shift.
Starter motor is under inlet manifold at back of engine.
Bell housing is part of gearbox.
CT
Postby CT » Thu Jun 22, 2006 1:08 pm
lam.666 wrote:sorry should of said 5 speed only, i think the 6 speeders have a different ration 3.9 / 3.6??
while the five speeders are a 4.11
That's the diff ratio - totally independent of the gearbox.
Moggy
Postby Moggy » Fri Jun 23, 2006 11:56 am
I think the NA8 gearbox has a larger input shaft than the NA6. The throw-out bearing definitely has a larger internal dia. on the NA8 5 speeder. This would tend to indicate that it is stronger. However, I have put 130-odd rwkw through my NA6 gearbox for a while now with no ill effects, and I haven't heard of this gearbox having strength problems...
Edit: I should have added that although the input shaft is bigger on the NA8, the spline that goes into the clutch plate is the same size and as someone has pointed out earlier in this thread, all NA and NB gearboxes will bolt up to an NA or NB engine.
