so what are some other ways to tell & how much are injectors? & an average cost to have a mechanic put them in..
hrmm, another thing to add to the list of maintenance.
kitkat wrote:how is the fuel consuption? blow smoke from being to rich?
anyway injectors are easy to change and you could do it yourself if you are mechanically minded. Cant remember the exact way to do it but it aint hard.
kitkat wrote:anyway injectors are easy to change and you could do it yourself if you are mechanically minded. Cant remember the exact way to do it but it aint hard.
CT wrote:If you are worried, take off the fuel rail and injectors, and get them pressure checked and the tips and o-rings replaced. It costs about $10-15 per injector. I always keep a set of o-rings handy so I can change them every time I pull the injectors out. I have found that they leak often if removed and replaced without new o-rings. Lubricate them with some oil which helps them seal when you replace them.
