Okibi's Electronic Boot Release Saga
Posted: Wed May 17, 2006 5:59 pm
Well today I got some time off to try and install my electronic boot release.
I used Fig's instructions from this page .
I thought i'd test to see if the pulse was strong enough for the actuator instead of wiring in a relay, so I connected the wires and pressed the 3rd button on my keyring.
Now my central locking wont work.
The alarm siren doesn't sound.
If I try and turn it off/on at the siren it doesn't make the usual chirp sound.
If I turn the alarm on, the indicators flash and the car arms itself (but wont lock the doors).
If I trigger the alarm it flashes the indicators.
The Microwave Sensor still triggers the alarm.
When I disarm the alarm the indicators flash about 4 times (but dont unlock the doors).
The 10 Amp \"door\" fuse looks ok and i've tested it with another fuse.
I have tried disconnecting the battery for 30 seconds to try and reset it.
Any other fuses/relays I should be testing?
Any advice?
Any advice?
