Fitting a new gear knob...
red63sprint
Postby red63sprint » Tue May 16, 2006 5:56 pm
Does the gear knob just screw off?
Or is there a lock nut under the boot I need to loosen off first?
I have just bought a Voodoo Gaer knob...
ta
David
1993 Clubman, Mx5plus roll bar
Autotechnica seats, Revalved Bilsteins
Fatcat Motorsport adjustable suspension
Espilier springs, Whiteline front bar.
Bevan
Postby Bevan » Tue May 16, 2006 5:57 pm
Turn anti-clockwise as hard as possile. You'll hear a 'click'. That's just the glue (or similar) breaking. Screw it off and screw the new one on! :)
rodent
강남 스타일
Postby rodent » Tue May 16, 2006 6:15 pm
Where did you get your Voodoo knob? Was it the one from eBay?
They don't seem to make'em anymore, and Mania have sold all theirs. :cry:
jonno.
Philip Lee
Re: Fitting a new gear knob...
Postby Philip Lee » Tue May 16, 2006 6:21 pm
red63sprint wrote:Does the gear knob just screw off?
ta
David
if u have the factory rubber ones then it's screw off.
if u have a nardi (eg some Jap import) then there is a nut at the bottom.
Curly
Postby Curly » Tue May 16, 2006 8:00 pm
I'd be interested to see the weight of an aftermarket knob.
I was surprised at how heavy the factory NA knob is - I assume it is there to give the gearshift a bit more momentum between gears and improve the feel of the shift.
red63sprint
Postby red63sprint » Wed May 17, 2006 8:46 am
Thanks dudes.
I bought the one off E-bay.
Cost too much I know - but its the first day of my holidays!
Crazy Red still sell em: http://www.crazyred.com/cri/pages/voodoo.html
Weight of Voodoo knob is 190g. Original knob weighs 145, so similar.
I am a pudden, so weight of car is no issue.
My weight is more of a problem :roll:
David
StanTheMan
Postby StanTheMan » Wed May 17, 2006 9:05 am
145g is that all? i thought it was a lot hevier than that
Richee
Postby Richee » Wed May 17, 2006 9:07 am
StanTheMan wrote:145g is that all? i thought it was a lot hevier than that
Voodoo Knob to be a 1-7/8 inch sphere of alloy, which gives it a weight of approximately 145 grams. This weight compares favorably with the OEM knob's 190 grams and, consequently, little vibration reaches the hand."
I think Red63sprint has it around the wrong way
Richard
Mazda Tribute - its a boat
red63sprint
Postby red63sprint » Wed May 17, 2006 11:45 am
I did have it the wrong way around - how does that work - a block of aluminium weigh less than plastic????
But Crazy Red says:
Bob tells it like this...
\"Originally, my intent was to simply make a shift knob for myself that met my needs... a spherical shape, custom fit to the Miata, and a weight at least somewhat in line with that of the OEM knob. The weight is important because the shift knob being too light causes a lot of gearbox vibration to be passed to the hand, and most people find that objectionable. So I designed the Voodoo Knob to be a 1-7/8 inch sphere of alloy, which gives it a weight of approximately 145 grams. This weight compares favorably with the OEM knob's 190 grams and, consequently, little vibration reaches the hand.\"
