Alternator Light on
Russellb
RIP Nov 2014
Alternator Light on
Postby Russellb » Thu May 04, 2006 10:05 am
Ok my Alternatot light is on. I have checked fuses ect and even checked the charge rate and I have 14.7 volts :D so why the f##k is the ALT light on :cry: . Any Ideas
My ClubmanRebuild
MX5 SE Rally car is HERE :)
jules
Guitar Hero
Postby jules » Thu May 04, 2006 12:13 pm
Nope. but a sparky might??
Jules
Andrew
Postby Andrew » Thu May 04, 2006 12:14 pm
Checked your belts :?:
Russellb
RIP Nov 2014
Postby Russellb » Thu May 04, 2006 1:22 pm
Took ALT toSparky he checked and it works fine
Put back on with new belt and the light is still on :cry:
checked with the sparky he has no Idea unless i leave it with him
My ClubmanRebuild
Moggy
Postby Moggy » Thu May 04, 2006 2:55 pm
14.7 volts sounds a little high. I thought they usually charge in the 13.5 to 14 volt range. Maybe your diode in the inst cluster is broken?
Postby 93_Clubman » Thu May 04, 2006 3:22 pm
could it be linked to your recently installed autronic which i assume replaces the standard ecu?
Russellb
RIP Nov 2014
Postby Russellb » Thu May 04, 2006 4:28 pm
Not an Autronic problem this is my other car I just got
And its not an cluster problem had a spare and swap them withe the same result :cry:
My ClubmanRebuild
