Does anyone know of a walkthru 4 a NB8B plug change?
Done them heaps of times on other cars, but I want to make sure that i don't wreck anything. I'm an old tmer used to just taking the leads off and viola, but this looks more complicated.
Cheers all.
Walkthru 4 NB8B plug change???
- ma64rk
Take the road less traveled...
Silver 01 w/hardtop & stylebars...
- Bevan
You can take the strut brace off if you like to make more room.
Unscrew the bolts that hold the two coil packs on and pull everything out. The 2 with the coils, just pull up on the coill, the two with the leads, just pull the plugs off.
You'll need the small spark plug socket with a LONG extension. Those pods are deep and narrow.
When putting it together it's obvious where they go on again if you forget to make note of where they go.
- Bevan
- sabretooth
- Vehicle: NA8 - Turbo
