Hiyas!
Can someone please tell me where I would find the ecu on my na6?
cheers
ecu location?
- rain902
ecu location?
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
- Garry
Underneath the passengers feet. If you lift up the carpet at the front of the passenger side footwell you will see a silver cover with 4 nuts and a bolt holding it in. Undo the nuts/bolt and remove the cover, but be careful it has really sharp edges, and you should be looking at the ECU.
- rain902
Garry wrote:Underneath the passengers feet. If you lift up the carpet at the front of the passenger side footwell you will see a silver cover with 4 nuts and a bolt holding it in. Undo the nuts/bolt and remove the cover, but be careful it has really sharp edges, and you should be looking at the ECU.
manythanks Garry - i saw that, didnt take the extra step of lifting it. Im off to the garage now, with a socket set
