13B Turbo -Legal for NB and some NA!
Sean
Postby Sean » Tue Apr 25, 2006 12:05 am
That's right kiddies,
I've been doing some investigations with the DoTaRs for my new car and it looks like thae changes to light car modifications may well allow rotary fans to legally fit a 13b Turbo to an MX5 8)
Approval under Code LA1 allows for \"Fitting of replacement engine with not more than 20% greater weight and or power than engines offered by the first manufacturer as a standard or optional engine.\"
Then it must fit into teh following equation (for vehichles between 800 and 1100kilos)
Original weight in kgs x 2.5 = Max capacity in ccs.
\"The engine capacity used for rotary engines is twice the swept volume of all rotarts\"
What this means is a 13b has a \"capacity\" of 2616cc.
So working with the formula:
Weight(kg) x 2.75 MUST = 2616 (cc)
So weight MUST = 2616/2.75 (or more)
So weight must equal 952 or more....
Now an NA weighed from 940 to 990 dependant on year model and options, so SOME NAs would be eligable.
NBs weighed just over 1000kg, so they are definately in.
Then you need to meet emissions requirements, the engine must be newer than the car and comply with ADR emissions standards ADR 37:01.
A series 6 onwards RX7 will comply with these ADRs, as long as you get an engine/frontcut from an RX7 newer than your MX5.
There are a few other bits and pieces that'd need to be worked out but it looks positive for rotarians 8)
Not sure how we'd go on teh powe not exceeding an additional 20% of the original, but definately go for NBs who had teh SP as an original mazda variant 8)
Oh and NO, I'm not building a 13bt mx5.
EGG80X
Postby EGG80X » Tue Apr 25, 2006 12:18 am
Yay thats good news
Babalouie
godfather of saké
Postby Babalouie » Tue Apr 25, 2006 12:28 am
My 1520kg Luce goes pretty hard as it is, so with 550kg less an NA would be bloody frightening :)
BTW, my NA weighed in at 1040kg with a full tank of gas (incl Brown Davis, etc etc) and the S6 13BTs are quite different from the S4/S5 ones. Eg it's actually a big job to put a S6 engine in an S5 RX7 because the mounts on the block are different...dunno if it would make it easier or harder to install in an MX5 tho...
maxwolfie
Postby maxwolfie » Tue Apr 25, 2006 2:42 am
your crazy sean
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
Duj
Postby Duj » Tue Apr 25, 2006 3:14 pm
Thats Great news sean!
the Bad news is no one on this site has the balls to do it! :lol:
what a shame!
I advertised a whole conversion for $3,000 including an engine, computer and ignition system.
no one bought it so i separated it... :?
A s6 engines are way better than s4/5 13bs, not sure bout fitting one to a s4/5 but changing the front cover to a 12a type and it will fit into anything with a front mounted crossmember,any early mazda etc...
StanTheMan
Postby StanTheMan » Tue Apr 25, 2006 5:25 pm
Duj wrote:Thats Great news sean!
what a shame!
errr i know 1 person does.....hold on thats you. :shock:
:mrgreen:
10years ago i started asking about turboing an NA (before kids).....general answer was.....no one here is really set up for it for the tuning of it & so on. They were doing it a bit in the US & Japan at that stage.
I have a feeling, thats where the rotary convesions are up to at the moment. Although a few conversions have been done. I feel you are really still at the pioneering stage of rotary conversions. It could be....that your conversion kit is just a little ahead in its time. I wish you good luck in the sale.
sabretooth
Postby sabretooth » Wed Apr 26, 2006 9:25 am
What about emissions laws? From memory you can't install an older model of engine in a newer vehicle because it doesn't meet emissions laws.
duj, why didn't you keep the kit and use it on your car?
Duj
Postby Duj » Wed Apr 26, 2006 1:39 pm
sabre- I was going to use it on my car but it already has a decent 12at and is too fast as it is :lol:
more people need to do this conversion!
awesome power, just rolls on beautifully 8)
I have a pic of my new setup with water2air IC if anyone wants to see it/host it for me?
[/img]
sabretooth
Postby sabretooth » Wed Apr 26, 2006 1:53 pm
duj: ahh, I see. If you want an image hosted, go to http://workshop.sabretooth.id.au/imgupload.php. Give it your image URL (remembering to remove spaces from it first) and it'll do the rest.
Sean
Postby Sean » Thu Apr 27, 2006 7:15 pm
apsilon wrote:
sabretooth wrote:What about emissions laws? From memory you can't install an older model of engine in a newer vehicle because it doesn't meet emissions laws.
That's what I was going to ask.
Also when I looked into it way back there was also an additional factor for turbos. Is that no longer the case? At the time I could've fit a 13b no worries but the engine was considered to be too large if it was a 13bt. I ended up just doing a turbo kit on the original engine.
Like I said above, the 13b would need to be series 6 onwards to comply with ADR 37:01 which is emissions, the newer the recipient car, teh newer your donor car will have to be.
As for the turbo multiplier, that's considered in the formula:
If the car is remaining NA then you replace the 2.5 with a 4.0.
Original weight in kgs x 4.0 = Max capacity in ccs.
Which means it could technically be legal (if possible :oops: ) to drop a commodore V6 engine into an MX5
hugh_ness
Postby hugh_ness » Thu Apr 27, 2006 8:06 pm
Well, it sounds farkin' good all this, but, think of all the beer that money could get ya.
I am thinkin' about doing something to Bene along the lines of turboing the thing or sticking a rotary in it.
I will be reading these threads with interest...
kula
Postby kula » Thu Apr 27, 2006 11:21 pm
interesting indeed.
my NA is factory quoted at 950kgs.
do they (rta) go on that or your actual weight?
im semi thinking of engines for my car..
and i reckon id want something NA, lighter than stock, and about 140rwkw
renesis or f20c seem to be at the top of the list:P
Duj
Postby Duj » Fri Apr 28, 2006 10:47 am
so is anyone SERIOUSLY going to do it? 13bt?Renesis?
or shall we just wait for the next MX5/ROTOR thread in a month or two so we can all say \"yeh im thinking bout it\" again? :lol:
would love to see more rotor mx's out there! 8)
Lev
Postby Lev » Fri Apr 28, 2006 1:20 pm
Me too, sorry Duj would have bought your kit but ended buying a boat instead now me broke :frown:
Was talking to a mate whose got a 20b cosmo, he said queensland roads didn't know how to class it so its registered as a 4 cylinder :shock:
Not a bad 4 cylinder upgrade for an MX I say, pitty about their weight.
Duj
Postby Duj » Fri Apr 28, 2006 6:02 pm
lol, nice question :lol:
Its really suprisingly quite good! 8) ,
I can go for a massive cruise all night long on $30 worth of Bp Ultimate (all i use) and thats usually $1.40/$1.50 a litre and still have petrol left the next day :D
when im cruising its ok, il do a check once its back on the rd
from what i can remember my old 1.6 NA would really drink it when i was thrashing through the hills and revving out gears, the rotor doesnt need to work as hard, so thats why i think its better
peeps probably wont beleive me but its true!,
