Revs question
fig
Revs question
Postby fig » Fri Apr 21, 2006 5:41 pm
Hi all,
Wondering if someone can answer this.
When I take off (cold start), each time I slow to a red light the revs drop to about 600rpm and the car does a little dance :P /shake, then reverts back to a nice idle. This only happens for the first 10mins from a cold start.
Any thoughts
PS, I just replaced the Plugs with Iridiums 3 months ago (they were my first thoughts for the origin of the prob.????)
Thanks In Advance
Then
10AE (#3062)
Now
'08 Porsche Boxster S modified ;-b
'11 Porsche Cayenne 22's FTW
'78 Porsche 911SC - Old Skool Hotness
'67 Porsche 912 - Fav!
sabretooth
Postby sabretooth » Fri Apr 21, 2006 7:15 pm
Have you tried resetting the base idle speed?
Is the idle-up occurring to make the car rev faster when it's dead cold?
Inf3ct0R
Postby Inf3ct0R » Sat Apr 22, 2006 1:11 pm
its called a idle dip, ECU problem, mazda USA know of it, but dont know how to fix it. all nb8a have this problem..
JSE
Postby JSE » Mon Apr 24, 2006 1:27 pm
My NA6 is opposite...after popping the clutch n coming to a stop it will idle at about 1500rpm for maybe 3 seconds then it will drop back down to 1000. Opposite of idle dip?
Sheck
Postby Sheck » Mon Apr 24, 2006 10:32 pm
i've got this problem, but i am running a turbo and an rx7 afm, and from my dadt logings i can see that the afm shuts really quickly but there is still more air coming in ie the voltage from my map sensor tells me that there is more air than the afm is saying there is, so it could be the spring tension on the afm
OR
try adjusting the point at which the little shock absorber thing on the throttle body comes into contact with the screw on the throttle plate.
Its just to the left of the throttle, and it kinda looks like a fuel pressure regulator at the top, and on the bottom its got this black rubber boot thingy on it. (i adjusted this and it helped a little with my prob, but didnt fix it completely)
Dave
