Idle dip......Gearbox problems?
- Hot Rodders
I have a 99 build 2000 1st reg NB with 23000k on the clock. Recently, at times when coming to a stop at lights etc. the idle will dip by a couple of hundred revs and then return to normal idle. When I first got the car, there was talk of a gear box problem with late NA & early NB with a thrust bearing? problem. Can anyone advise where I can find details ( have looked but can't find ) on this matter. Do I need to worry?
Hope some one can help.
Cheers!
Cheers!
- Li7hium
What is it like on starting up?
Have you recently had a dead battery?
Sounds like a problem I had after my battery went dead a month or so ago. In my situation, I had to alter the manual idle speed. ECU kicks in a tad afterwards which accounts for the idle speed coming back up, but if your base idle speed is below 800 RPM then you are going to keep getting the dip until the ECU kicks in.
Matt
Matt
NA8
Wakefield 1:14:78 28-6-09! Oran Park GP 1:27:73 30-03-08 Oran Park South 54:50 14-10-2007 Eastern Creek 2:02:44 6-8-07
BRZ
Pheasant Wood 1:05.4940
BRZ
- Hot Rodders
- Li7hium
Fair enough, if you do want to check your base idle, see this thread which has a link to the Miata Garage page dealing with idle issues.
Good luck in the search for the remedy.
Matt
Matt
NA8
BRZ
BRZ
- Hot Rodders
- Li7hium
I've done a few searches on the archived forums. Are you getting a screeching sound at idle, or grindy grindy noises?
All of the threads I've looked at regarding thrust bearing issues either have a rattle of the clutch when depressed or a scratchy / screechy sound.
NA8
BRZ
BRZ
- Matty
- Alf
- Garry
If the thrust bearing in the engine is stuffed the revs will slow when you push the clutch pedal in. It has only happened to a relatively few cars in the US. I've never heard of it happening in Australia so I think it sounds like it's a problem for US engines. I wouldn't stesss to much about it if I was you.
Sounds more like the base idle speed is to slow to me. I'd try adjusting that first as it's the easiest/cheapest thing. This is a tuning issue and totally seperate to the thrust bearing thing. Idle dip has been an MX5 problem in varying levels of severity from the first NA's to the last NB's. Especially once they get a bit of wear on them. It wont affect engine longativity. It may eventually drive you insane though if you cant find a cure.
The only thing that helps my idle dip is cleaning out the idle bypass screw passage. It's a right PITA to get the idle adjuster screw out but after a good spray of throtlle body cleaner down the screw hole and a general clean of the throttle body it idles like it's supposed to.
Just be careful not to strip off the black sealant stuff around the throttle plate with your throttle body cleaning or it'll be idling to fast............dont ask me how I know this.........
- Hot Rodders
- Woo
- Vehicle: 10AE - Turbo
Having learned to live with the idle dip over the last 18 months I found that when I replaced the fuel regulator today that I no longer dip
Might just be the blue cars way of saying thanks for more fuel, but none the less worthy of a mention.
Wòó
Wòó
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
- fig
Blugg wrote:I've got the same problem too. It goes away when the car is warmed up though. Only on cold start.
ditto
Then
10AE (#3062)
Now
'08 Porsche Boxster S modified ;-b
'11 Porsche Cayenne 22's FTW
'78 Porsche 911SC - Old Skool Hotness
'67 Porsche 912 - Fav!
10AE (#3062)
Now
