broken rubber boot on shifter..
green_comet
Car Detailing Guru
Postby green_comet » Mon Apr 10, 2006 9:20 pm
Hi everyone,
I finally got time to check the oil in the gearbox turret tonight, when i pulled the shifter out, i noticed that the rubber boot on it was torn in half..
Can these be replaced? I couldnt find any way of getting the boot off the shifter...
can anyone recommend anything? If it can be replaced? how to get it off?
cheers
Ryan
Juffa
Postby Juffa » Mon Apr 10, 2006 9:46 pm
Ryan, welcome to the joys of MX-5 ownership. What you have come across is pretty much standard. All 3 MX-5s that I have owned had this same problem. There is info the miata.net garage page on replacing both the gear stick rubber boots. The prices at your Mazda dealer are not too bad, especially if they are a club sponser.
linky ==>> http://www.miata.net/garage/shiftboot.html
While the boots will be a tight fit they will pull over the shaft of the gear leaver.
J
green_comet
Car Detailing Guru
Postby green_comet » Mon Apr 10, 2006 10:00 pm
Dont u just hate that problem...
*immature girlish laugh*
Man im sad.. :lol: :P
Cheers for the help Juffa man, ill get it all sorted... :mrgreen:
OMY005
Postby OMY005 » Mon Apr 10, 2006 10:22 pm
Some more info and part numbers here. :)
http://www.aus-cartalk.com/viewtopic.ph ... highlight=
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
