Brake Disc Thickness
tasroadster
Postby tasroadster » Sun Apr 09, 2006 5:31 pm
What's the min. thickness for 1990 NA front Disc's ?
What's the thickness of the NA8 front disc's..... are they the same as the NA6 ? They are 255 mm right ?
Any help greatly appreciated.
Thanks
Inf3ct0R
Postby Inf3ct0R » Sun Apr 09, 2006 8:35 pm
na8/nb8a are 255mm, na6 are smaller.
min thickness for the 255mm should be 20mm... i think.
the figure should be casted onto the disc, around the hub area on the inner side
tasroadster
Postby tasroadster » Sun Apr 09, 2006 8:39 pm
So I can use 255mm disc's which are 21 mm thick ?
Thanks
Inf3ct0R
Postby Inf3ct0R » Sun Apr 09, 2006 8:41 pm
yup, I had mine machined down to 19mm
tasroadster
Postby tasroadster » Sun Apr 09, 2006 8:50 pm
So.... what happens if I just run then at 21 mm thick ?
Is there any problems with that ?
Thanks
Inf3ct0R
Postby Inf3ct0R » Sun Apr 09, 2006 9:12 pm
nope, once you hit 20mm, i'd be looking at buying new rotors, they are at a higher risk of cracking/overheating
tasroadster
Postby tasroadster » Sun Apr 09, 2006 9:19 pm
So leave them as is ?
Thanks
Inf3ct0R
Postby Inf3ct0R » Mon Apr 10, 2006 1:05 am
depends on how hard your driving and what pads your running, but once you get them machined and hit 20mm then replace them..
tasroadster
Postby tasroadster » Mon Apr 10, 2006 1:14 am
machine them to what thickness?
20.5 mm ?
Thanks
Craig
Postby Craig » Mon Apr 10, 2006 1:20 am
Here's some disk info to assist.
Inf3ct0R
Postby Inf3ct0R » Mon Apr 10, 2006 1:20 am
the machinist should be machining to whatever thickness is needed for a smooth consistent surface.
Inf3ct0R
Postby Inf3ct0R » Mon Apr 10, 2006 1:24 am
well, there ya go min thickness 18mm
must have my stock disc @ 17mm or something then LOL
btw, if your disc are 21mm, then they sound brand new!!
