Brake Proportioning Valve
Has anyone tried to eliminate this valve? (divert it)
It should give a better bias to the rear brakes.......right?
Any help would be greatful.
Thanks
Thanks
- sabretooth
- Vehicle: NA8 - Turbo
- CT
Trust me - you can't remove it without stuffing up your front to rear bias - badly. Matty has written of using a later model valve on earlier cars. If you are really stressed, start playing with rear pad compounds or open your wallet and get an adjustable one fitted in it's place.
- Matty
tasroadster wrote:Is an adjustable bias valve legal?
Thanks
I believe it should be, if it's not mounted in the cabin. (ie replace the OEM one under the bonnet). You'll need a few adaptor fittings to make it all work.
Removal of the valve entirely would probably be unsafe, though I have heard of it done with good results for autocross use (the fronts were still locking up first). Do so at your own peril and with no approval from me. Search the big forum...
As said, I have an NB prop valve on my car which made a noticeable improvement in braking. part number is NC10-43-900A but you'll have to order it in. It will probably cost more than an adjustable valve...
- sabretooth
Matty wrote:I believe it should be, if it's not mounted in the cabin.
This agrees with what I have been told.
- maxwolfie
- Bevan
maxwolfie wrote:Not trying to start anything, but why would you want to do this anyways (Just out of interest)
Matty wrote:I have an NB prop valve on my car which made a noticeable improvement in braking.
- CT
You can increase yor braking performance by adding more rear bias in general than factory. It has transformed my race car's braking to the point that I can adjust it mid corner so if I am locking a brake I can stop it immediately. In the wet, it even more important as you need to run much more rear bias.
If you really need to do it on a road car, I'd say it's more likely that something isn't working properly. Easier totry a retrofit as Matty suggests or different pads front to rear. I don't know that you'd need adjustability unless you have wildly altered the weight distribution or caliper piston sizes of the standard car.
- Matty
CT wrote:I don't know that you'd need adjustability unless you have wildly altered the weight distribution or caliper piston sizes of the standard car.
two reasons to choose an adjustable valve:
1) it's cheaper
2) it means you don't have to try a dozen non-adjustable valves to find the best one.
Once it's dialled in you should pretty much be able to forget about it - with the possible exception of a radical change in pad compound.
(NB: higher-mu pads front and rear will give you more rear bias, by lowering the required hydraulic pressure)
- Astroboysoup
I just ahd a quick read through the 44 page adr on brakes and it says nothing about changing brake bias.
but if you change them they have to still meet the other 6 part specifications. i would list them but each part has about 20 dot points
AustCars.net - It's like Facebook but for cars!
- CT
Matty wrote:CT wrote:I don't know that you'd need adjustability unless you have wildly altered the weight distribution or caliper piston sizes of the standard car.
1) it's cheaper
Fair call - except for those reasons!!
- rain902
re
for reference, wilwood adjustable valve is about $120, plus installation
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
- rain902
tasroadster wrote:Who / Where from exactly???
Thanks.
my mechanic, maranello motors http://www.maranellomotors.com.au
got it for me and installed it - he does a lot of race prep on a lot of different cars - also services my work van - a good man.
