it's done, glens turbo results
glen73
Postby glen73 » Mon Mar 20, 2006 8:29 pm
well im just about ready to do finnishing touches to under the hood for the turbo install, now i need the ecu put in and tuned. does anyone know of any decent tuners in melbourne area?
cheers
glen
Sean
Re: help with microtech ecu
Postby Sean » Mon Mar 20, 2006 10:39 pm
glen73 wrote:well im just about ready to do finnishing touches to under the hood for the turbo install, now i need the ecu put in and tuned. does anyone know of any decent tuners in melbourne area?
cheers
glen
Maztech Of Melbourne Pty Ltd
264 Dundas St Thornbury VIC 3071
t:(03) 94168411
Anthony is the King 8)
He was one of the Pioneer's of EFI 4cyl and rotary racing here in Australia and now spends time all over the world tuning.
glen73
Postby glen73 » Tue Mar 21, 2006 6:00 am
wow thanks, he sure sounds like he knows his sh!t. :lol:
glen73
Postby glen73 » Wed Mar 22, 2006 10:40 am
just spoke to maztech, not only is he going to put a base map on me ecu he also wants to know what injectors, turbo, ignition etc. this is excellent service as he is matching my ecu with my project roughly. im not expecting everything will be smooth sailing when i turn the key for the first time but hey its better than the simple stock base map.
ive only had my microtech a short time but i got to admit there customer support is A1.
maxwolfie
Postby maxwolfie » Wed Mar 22, 2006 12:03 pm
glen73 wrote:just spoke to maztech, not only is he going to put a base map on me ecu he also wants to know what injectors, turbo, ignition etc. this is excellent service as he is matching my ecu with my project roughly. im not expecting everything will be smooth sailing when i turn the key for the first time but hey its better than the simple stock base map.
That's always a good thing :) Hope the map goes well
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
lowmiata
Postby lowmiata » Wed Mar 22, 2006 4:32 pm
glen73 wrote:ive only had my microtech a short time but i got to admit there customer support is A1.
wait till you have to deal with microtech direct.......................
you have been warned
EVI15 1998 to 2008
glen73
Postby glen73 » Mon May 01, 2006 6:15 pm
i posted this here aswell sean to see who knows what..... well i have my ecu back from maztech in melb. its reconfigured and also ready for my 460cc injectors. he said once it is in i will be able to drive it to him for tunning as he played a little further with the ecu to make sure it knows its running a turbo. he told me not to drive it hard or anything silly just drive it to him. now he gave me a sheet which i understand fairly well as far as the diagram for the microtech goes but i cant make heads or tails of the haynes factory ecu diagram. also im confussed as to what will run the \"power steering pressure switch\" or the \"A/C relay\" or the \"inhibitor switch\" (what ever the hell that is)for example. do you leave the old ecu to run these sorts of things or do you cut the old one out completely?
timk
Postby timk » Mon May 01, 2006 7:58 pm
As far as I know you leave the stock ECU in to do those things.
glen73
Postby glen73 » Mon May 01, 2006 8:26 pm
so to clarify its as follows
igition output 1,2,3,4
injector drive 1,2,3,4
T.P.S. input
oxygen sensor
fuel pump relay
air temp sensor
water temp
crank input 1,2
vac boost
and of course battery ground etc...
is this all to do?
if this is this the case its looking pretty easy...and the ecu dude wants $200 to do this
ha
Russellb
RIP Nov 2014
Postby Russellb » Mon May 01, 2006 8:27 pm
P/S Pressure switch just Idles up the car when on full lock
the A/C is a bit tricker but can be done
What model do you have? I have the wiring Diagram for NA6 NA8 NB8A
glen73
Postby glen73 » Mon May 01, 2006 8:35 pm
na6
if you feel like making someone very happy you can E-mail it to limp5@tpg.com.au
:mrgreen:
Russellb
RIP Nov 2014
Postby Russellb » Mon May 01, 2006 9:56 pm
Tryed to Email files to big as I'm only on dial up :frown:
but hear are the pics
Hope this Helps :D
glen73
Postby glen73 » Mon May 01, 2006 10:01 pm
thanks heaps russ...onwards and upwards.
BTW now is what im doing piggybacking? if so is this good or bad? should i just take it to maztech and get it installed there as a standalone although this would cost heaps.
Russellb
RIP Nov 2014
Postby Russellb » Mon May 01, 2006 10:20 pm
Couple of things
1) Does the Microtech need a proportional TPS
2) Does it have extra inputs/out puts If so this could be used to drive the A/C
3) You dont have to worry about the P/S Switch
4) Are you going to try for P&P or run a new harness
This is probable the best Option as you can get full Sequential Injection
This is what I did for My old Man's NA6 I also modifided the T/Body to take a proportional TPS
And I just finished a P&P autronic into my NA8 Clubman :D
glen73
Postby glen73 » Mon May 01, 2006 10:27 pm
ok, no A/C,,,its gone. now proportional tps. i dont understand. it does have extra inputs/outputs. i already have a new haness. as you have gathered by now i know little but feel i can wire it up. so what is tps? the only reason i ask all these piggy vs standalone questions is it really a big difference in performance or not just doing the piggy style?
