How to change Spark plugs?
Matty
Postby Matty » Sun Mar 19, 2006 9:02 pm
pull off ignition leads (only at the pug end, not at the coil or you'll forget which one goes where)
with 5/8\" spark plug socket on an extension, unscrew old plug and remove.
Grab new NGKs, insert into socket. insert socket into well.
Turn backwards (anticlockwise) until you hear it click. Then screw in finger tight.
Tension a further 1/4-2/3 of a turn (IIRC) with the socket handle. (it's written on the box)
Optionally you can put a dab of antisieze on the threads, but be careful not to get it on the electrodes.
Reconnect leads.
CT
Postby CT » Sun Mar 19, 2006 9:30 pm
For the NB8B and later models you will need to undo and remove the coils which sit on top of the plugs. Nothing too hard. Also an idea to check your gaps just in case the plugs have been \"adjusted\" since leaving the factory. 8)
ducktape69
Postby ducktape69 » Mon Mar 20, 2006 4:43 pm
took me 2min to do on my nb8b....
i didnt gap the NGK plugs though...should i be gapping them? if so ..how many mm should i gap it to?
ma64rk
Postby ma64rk » Fri Apr 07, 2006 2:37 pm
what is the correct gap for standard 1.8 2001?
Take the road less traveled...
Silver 01 w/hardtop & stylebars...
rodent
강남 스타일
Postby rodent » Tue Jun 06, 2006 6:11 am
Going by memory, I think my Iridiums specified +1/3 to +2/3 on the box itself. Check the packaging on your own plugs.
Edit:
Matty wrote:Tension a further 1/4-2/3 of a turn (IIRC) with the socket handle. (it's written on the box)
Well there you go :P.
jonno.
jules
Guitar Hero
Postby jules » Wed Jun 07, 2006 2:43 pm
I put a small dab of oil on the thread as well. Help getting them in and out later.
Jules
rodent
강남 스타일
Postby rodent » Wed Jun 07, 2006 4:32 pm
ralphie wrote:so until it clicks then add 1/4-2/3 of a turn??
cheers
It doesn't "click" as such - just turn it till you get some nice solid resistance, then tighten to spec as it says on the box.
You'll know what I mean when you try it 8).
jonno.
