Quick Shifter Kit
Posted: Fri Feb 17, 2006 10:09 pm
by Hammer
Hi guys
Has anyone fitted a
quick shifter kit on their gearbox? In particular for the 6-speed NB8B? All opinion welcome.
5 & 6 Speed Quick Shifter KitsIf you thought the standard MX-5 gearchange was great, this quickshifter makes it even more delightful. Greatly reduce the gear change "throw" and improves shift feel.
Posted: Sun Feb 19, 2006 1:47 pm
by slowpoke
G ' day Hammer... Russell of Carco fame, in Canberra, supplied and fitted a quick shift to my 5 spd. and it improved the ' feel ' of the gearchange considerably. Slightly stiffer yes, but hugely better. Personally, I don't think the addition of a Q / S to a 6 spd. would be either helpfull or rewarding. Cheers, slowpoke
Posted: Sun Feb 19, 2006 2:47 pm
by Russellb
Like Slowpoke said I have fitted one to his car and to 3 other NA 5sp we have one in Pilsner's race car and my old mans NA both have a 6sp in them and once you get use to it it is great
Need more info call me on 0417 028 247
or (02) 6253 1395
Posted: Sun Feb 19, 2006 8:39 pm
by Hammer
Thanks guys
Posted: Wed Apr 26, 2006 8:59 pm
by Russellb
That's the one I have been fitting to All the car's hear who wanted them
go for it if you don't like It I'll buy it off you
Posted: Wed Apr 26, 2006 11:22 pm
by JSE
I got a short shifter installed for my NA6 just 2 weeks ago from MX5 Mania. Man...the throw reduction is awesome. Like it says on their website...if you thought the standard throw was good you should feel the short shifter. Definately back this mod up 100% it is awesome. Duno about the 6 speed but the 5 speed is great. Its also worth replacing the rubber shift boots while you are down their as well.
Posted: Thu Apr 27, 2006 11:56 am
by jolt
Hammer: There's some info on the six speed short shifters that I posted here which you might find interesting ...
http://www.aus-cartalk.com/viewtopic.ph ... c&start=90Russellb: Does that ebay short shift kit fit the six speeds as well?
thanks
Rod
Posted: Thu Apr 27, 2006 10:20 pm
by EGG80X
I got the IL motorsport quick shifter kit, works a wonder shift so short..... makes you want to drive harder lol.....
though the first week after install its a bit stiff.... but once you pop its cherry, you enjoy shifting gears so much more
Posted: Thu Apr 27, 2006 10:29 pm
by Russellb
They require a small modification but they can be fitted
Re: Quick Shifter Kit
Posted: Thu Jun 22, 2006 12:38 am
by Casey
Hammer wrote:Hi guys
Has anyone fitted a
Hammer -
check this posst.I just fitted one to my SP - I might have got his last one by the sounds of it
Posted: Thu Jun 22, 2006 3:55 pm
by Benny
I've had the ILS short shifter on my SP for about 2 years now, and It's fantastic!
When we meet up again Hammer, I'll give you a drive of my car and then you can really tell what it feels like.
If they are installed properly, and I got Dave from MX5 Mania to fit mine, they work so smoothly. They are a little stiff when brand new, but after a week of driving, they loosen up and the effort required is hardly more than with the standard shifter, but boy, the movement between gears is amazingly short. Almost like a switch.
It gives a really good mechanical feel to the shifter, unlike the woolly and rubbery feel the NC has.
