Page 1 of 2
Oil Filter Relocation Kit????
Posted: Tue Jan 17, 2006 9:12 pm
by sab
After doing an oil service last weekend, I'm sick of the oil dribble caused when removing the oil filter.
Anyone have an filter relocation kit fitted to their car?
Where would you mount the thing on a RHD NA???
I don't think removing the brake booser would be a good idea!
Posted: Tue Jan 17, 2006 9:19 pm
by lowmiata
I would mount it up front where the 200sx etc have there intercoolers mounted
to the side of the radiator
mine will be out the front with the rest of the cooling gang though!! hehe
Posted: Thu Jan 19, 2006 4:42 pm
by hillsend
my car came with an oil cooler and relocated oil filter inside the front grill next to the radiator, it still makes a mess with oil running over the inside of the bumper.
Posted: Thu Jan 19, 2006 6:34 pm
by Woo
It takes a bit of fabrication, but gee it makes the changes easy
EDIT "Whoops your looking at an NA, oh well maybe it's helpful anyway"/EDIT
Wòó
Posted: Fri Jan 20, 2006 9:42 am
by Bevan
Nice! Did you make that yourself?
Posted: Sat Jan 21, 2006 10:17 am
by Woo
Yes, just two pieces of flat 6mm steel welded into an inverted "T" with 3 holes in the base for the metal screws that were supplied in the kit.
The difficult bit of the install was that there was no thread in the fitting to go onto the block. The plug tap to suit cost $70
, so if anyone wants a loan just ask (very costly for just one thread).
Oh yeah, the fittings on the filter housing were also swapped to elbows to clear the bonnet.
Wòó
Posted: Sat Jan 21, 2006 11:29 am
by kula
rocket industries sell a kit,
me personally, ill put up with the slighyly awkward nature of filter removal and save the extra weight of the reloc kit. (it is a few kilos)
the 5 isnt that bad at all, compared to some cars.
Posted: Sat Jan 21, 2006 12:31 pm
by Woo
Kula, this is the Rocket kit which weighs in at 840g (including the bracket, fittings & hoses). It's dyecast aluminium and is very light.
The main reason I decided to do it was with the added fuel rail and injectors (motor is turbo'd) the access was even further restricted.
Good investment at $105 for the clean freaks that hate the "dreaded dribble".
Wòó
Posted: Sat Jan 21, 2006 8:22 pm
by greenMachine
They look like two right angle bends at the filter - what will that do to flow rates, especially when the oil iscold?
Any of our boffins have a view on that?
Posted: Sun Jan 22, 2006 2:39 am
by Okibi
I'd love to get the full greddy grex remote filter and oil cooler kit
Posted: Fri Jan 27, 2006 1:10 pm
by jolt
Apart from costing around $850 before shipping and duty, all the JDM remote mount oil filter and oil cooler kits are for the NA6/8 only, unless you go to one of the smaller specialist MX5 tuners.
Tuckin99 sell a kit for all MX5's at a comparatively reasonable $620 but it looks like it's pretty poor quality, I've seen
Item these oil cooler kits on ebay for just $250!! The lines and fittings look like bathroom items!!
Does anybody know what would need to be changed to fit the NA8 kit to an NB8?
Rod
Re: Oil Filter Relocation Kit????
Posted: Sun Oct 24, 2010 6:34 pm
by mitch_f1
sorry to dig up an old thread, but does anyone have pics of the mounting of their remote oil filter?
Posted: Sun Oct 24, 2010 8:57 pm
by fattima
This is the setup on my car. It was on the car when I bought it, the kit is from MX5 parts UK.
The location sucks and makes a mess when changing filters. For the new car I'm building I'm giving the relocation kit a miss and just having a take off plate for an oil cooler.
Posted: Sun Oct 24, 2010 9:08 pm
by mitch_f1
Hmm I've got my strut brace right there. I think the only option I might have is to remove the charcol canister
Posted: Sun Oct 24, 2010 10:09 pm
by NMX516
My oil filter is relocated to down beside the gearbox. It bolts to the side of the gearbox, and fits up between g'box and transmission tunnel, out of harms way. I don't have a photo of it that I can post unfortunately. I had it custom made by MX5Plus - Danny has a similar setup on his RX8, as per pics in his Renesis engined NC garage thread on page 28 -
viewtopic.php?f=57&t=30796&start=405Makes the filter change very easy, and drains straight into the oil tray at the same time as the sump oil does
I'll also go out on a limb and say that with it being down beside the gearbox, could potentially give some cooling benefit to the oil which an under bonnet relocation kit wouldn't be able to match due to air flow around the filter.
