HKS 264 degree cams
spikey
HKS 264 degree cams
Postby spikey » Wed Jan 11, 2006 11:36 am
Has anyone used this on their NA6?I bought them to try it on my Na6 turbo that I'm putting together,would it make much difference on a turbo car or are these made for Na motors?any info would be great.these have a 8.78lift on them.
Thanks
PASHN8
Postby PASHN8 » Wed Jan 11, 2006 11:50 am
Would make a good difference with a decent sized turbo and boost. I believe the best combo is a 264/272 combo for the street.
What sort of boost are you going to run?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Postby Okibi » Wed Jan 11, 2006 12:35 pm
G'day Spikey,
Have you become a member of the MX-5 Club of WA yet?
We have our monthly after work get together tonight at Wheelspin 1/30 Adams Drive Welshpool. Drop past and say g'day.
spikey
cams
Postby spikey » Wed Jan 11, 2006 10:23 pm
Okibi,Still fixing some side intrusion bars in my Legacy at the moment,so don't have time tonight but I will go to one of your meetings,Thanks.
Pashn8
I'm going to be running a Tdo5 16G turbo and I'm planning to run about 10-12psi.got the wiring harness for the Haltech made up,so it won't be long now then we can see how much boost it can take.
Postby Okibi » Thu Jan 12, 2006 12:29 am
If you don't end up putting those cam's in, i know someone in WA looking for a set.
PASHN8
Postby PASHN8 » Thu Jan 12, 2006 1:10 am
Trust TD05 or a Mitsubishi TD05?
- 2005 MX-5 SE
spikey
cams
Postby spikey » Thu Jan 12, 2006 2:34 am
Greddy tdo5.
PASHN8
Postby PASHN8 » Thu Jan 12, 2006 9:49 am
Trust/GReddy, same company :)
I take it its internal gated? what flange is that? WRX TDO5?
- 2005 MX-5 SE
spikey
CAMS
Postby spikey » Thu Jan 12, 2006 3:59 pm
IT COMES WITH A TRUST CUSTOM STAINLESS MANIFOLD AND WILL BE RUNNING A TIAL 38MM EXTERNAL WASTEGATE.IT IS NOT A WRX TDO5 FLANGE.
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Sun Jul 22, 2007 9:44 pm
What sort of response would you expect with just the 264 inlet cam and a standard exhaust cam (with boost)....?
AJ
Postby AJ » Sun Jul 22, 2007 9:47 pm
mismatched cams???........you need a glass of water mate :P :lol:
XMX5 Rogues
Sean
Postby Sean » Mon Jul 23, 2007 11:35 pm
Okibi wrote:If you don't end up putting those cam's in, i know someone in WA looking for a set.
http://www.aus-cartalk.com/viewtopic.php?t=26208
