HELP! ENGINE STALLING! NA6CE
PT
Postby PT » Mon Nov 21, 2005 2:58 pm
Most people will say idle speed controller, sounds more sinister than that to me.
Could with with a good clean out of the throttle body and probably CC.
Try a giving the thottle body a good cleanout with some carby cleaner.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Craig
Postby Craig » Mon Nov 21, 2005 3:06 pm
Does it behave better once it's warm?
PASHN8
Postby PASHN8 » Mon Nov 21, 2005 3:22 pm
IDENTICAL problem here bud! Did it this morning to be precise! once that first stall is over, and it warms up a bit, it runs perfectly!
Leads or plugs?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Craig
Postby Craig » Mon Nov 21, 2005 3:27 pm
Oxygen Sensor! :)
Matty
Postby Matty » Mon Nov 21, 2005 3:36 pm
out of fuel?
Craig
Postby Craig » Mon Nov 21, 2005 4:53 pm
SOCKET wrote:and your answer is oxygen sensor hey? hmmmmmm
Yeh it's trying to get a reading upon startup, can't get one, and then goes into a default settings mode.
PASHN8
Postby PASHN8 » Mon Nov 21, 2005 5:51 pm
You think so Craig? Is there a fault code or way to test this theory?
Maybe i'll swap the oxy over from my dad NA6CE Auto, and see if it makes a difference?
I would have though plugs/leads for sure, something electrical and heat related?
- 2005 MX-5 SE
Craig
Postby Craig » Mon Nov 21, 2005 6:01 pm
SOCKET wrote:so where do i get a new o/s from? mazda??? $500??!!!
Bosch make a unversal one apparently, so go hunting at Repco etc
PASHN8 wrote:You think so Craig? Is there a fault code or way to test this theory?
Unplug it! :P
Russellb
RIP Nov 2014
Postby Russellb » Mon Nov 21, 2005 6:29 pm
Had the same problem in my old mans 1.6 and a good clean of the earth wires to the PPF near the diff and earth near the wiper motor fixed the proplem
Dont ask me WHY it just fixed it .
lowmiata
Postby lowmiata » Mon Nov 21, 2005 8:34 pm
yep definatly O2 sensor!
new one from mazda 400 something!
repco have a single wire one for 53 bucks i think it is!
all you have to do is reconect a wire and you are away
you can disconect the o2 sensor when cold and see if it makes a difference ie the car wont run in closed loop i think it is because it wont get a reading from the o2 sensor
it runs fine and doesn't stall with it disconnected
atleast it will find the problem to find the wire for the o2 sensor just follow the wire up from the extractors and there is a brown or grey plug to the drivers side of the injector pack at the back of the engine!
EVI15 1998 to 2008
Matty
Postby Matty » Mon Nov 21, 2005 10:24 pm
interrogate the ECU first: http://www.mx5club.org.nz/maintenance/e ... agnostics/
I'm skeptical about the O2 sensor, without it the car should run fine, just a little rich.
lowmiata
Postby lowmiata » Tue Nov 22, 2005 7:00 pm
yep car will run fine but rich but its the effect of unpluging it to see wether it still stalls 30 sec into driving to highlight the problem.
mine used to do it at the end of my street at the round about always had to coast through it and hope to get to the other side !!
EVI15 1998 to 2008
sabretooth
Postby sabretooth » Tue Nov 22, 2005 9:44 pm
I don't think that it's the O2 sensor at all. I'd be more inclined to check for vac leaks, dodgy idle controller, dodgy coolant temp sensor wiring or a dodgy coolant temp sensor.
PASHN8
Postby PASHN8 » Wed Jun 07, 2006 4:06 am
Back from the dead....
The dreaded cold start gremlin has resurfaced... this time slightly different to the last time.
No stalling at the first set of lights, just dismal cold start/idle upon startup.
Starts/cranks over fine, engine catches straight away, then starts to run with a miss, like she's running on 3 cylinders, and all the while running rich as fark, because you can smell the strong stench of unburnt fuel out of the exhaust!
She runs like this for about 5 mins at idle, or until she starts to warm up, then she drives like a dream, strong smooth, no problems.
Mods are a set of of Genie headers, and 14 advance, that's it. I replace the leads, and 02 sensor about 7 months ago, and this problem has only started since the onset of the cold Melbourne winter, about a month ago.
Suggestions?
- 2005 MX-5 SE
jules
Guitar Hero
Postby jules » Wed Jun 07, 2006 2:27 pm
ECU???
Jules
