NC 2.5l engine swaps ?
- Boyracer
- MX-5 Encyclopedia
Re: NC 2.5l engine swaps ?
I have been doing a 2.5 Conversion, made a video, unfortunately didn’t put the phone sideways but it came up ok, it’s in 3 parts.
Will hopefully start on the cam swap soon.
https://youtu.be/8N6okstYt8c
looking forward to following this thru
2008 NC 2.5l conversion, Tein edfcpro, 4.1diff and a big smile
- Custardtart
Boyracer wrote:I have been doing a 2.5 Conversion, made a video, unfortunately didn’t put the phone sideways but it came up ok, it’s in 3 parts.
That’s what’s missing, a good vid of how to do it in the real world. Look forward to part 2
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
Looks good. I will defintely be doing the swap sometime in the next few years.
Where are you getting the cams from?
Custardtart wrote:Boyracer wrote:I have been doing a 2.5 Conversion, made a video, unfortunately didn’t put the phone sideways but it came up ok, it’s in 3 parts.
Have you joined the Facebook "NC MX5 2.5 Club"?
Some really good information on that page.
- StanTheMan
It seems like custard missed 2 other vids Boyracer already has....you just have to look a bit harder
- bruce
- Vehicle: NA8 - Turbo
Silly me - I didn't realise NC engines are Ford motors.
- Custardtart
StanTheMan wrote:It seems like custard missed 2 other vids Boyracer already has....you just have to look a bit harder
What am I missing? The only other vids on Lou’s channel are unrelated to the engine swap?
Lakeside 62.3
Lakeside 62.3
- StanTheMan
youre missing 2 other videos.
if lou teaches you how to transplant an engine....perhaps you should teach him how to make those other videos more visible.
just dig a little further down in his channel. they are there.
- Custardtart
StanTheMan wrote:youre missing 2 other videos.
just dig a little further down in his channel. they are there.![]()
Well bug**r me
Lakeside 62.3
Lakeside 62.3
- Boyracer
- MX-5 Encyclopedia
I struggle with the Youtube thing too, I will just do a quick one for the pulley refit, might be a while before I get around to the cam swap.
- StanTheMan
would these go into an NA chasis?
StanTheMan wrote:would these go into an NA chasis?
Probably, google shows a couple at least.
Biggest issue is that unlike a B6 to BP swap where a whole lot stays lines up, with the MZR pretty much nothing does, even stuff as simple as exhaust and intake being on opposite sides to the B series.
If you wanted a 2 litre (without boring out a BP) it's probably a bit simpler to go for an F series engine, probably the FE-DOHC (FE3 colloquially)
Intake/exhaust on same sides, MX5 gearbox I believe can fit if you use a B series ute, or E series Van bellhousing (or 929, but they were auto only)
But, you're still stuck with custom sump, and probably having to do something about the subframe.
Plus, the F engines are physically taller than a B engine, so you'll probably need to have a small bonnet hump or something to clear.
- StanTheMan
I mean I quite like the 2.5 im our mazda 3.
but yea....you may as well then do a far more serious engine if you have to go to the trouble of all that.
or just turbo
or just turbo
- bruce
Just weld up the rear doors in the Mazda 3, cut the roof off and voila......you've ruined a Mazda 3.
