US Headers & Exhausts NA
- zero00
Re: US Headers & Exhausts NA
hmmmm .. I'll take the potplant
Roger D-SUNSHINE COAST
- plohl
- Black_Penguin
Wouldn't make a difference, the idea is to have the 'pulses' of exhaust gas enter the collector at equally separate times. The order that this happens in is unimportant.
- gslender
Black_Penguin wrote:Wouldn't make a difference, the idea is to have the 'pulses' of exhaust gas enter the collector at equally separate times. The order that this happens in is unimportant.
Sure, but when built by Chinese factory workers, they use their wicked maths and dodgy looking welds to alter how hot gasses expand - so tried and well understood header designs don't apply here. So order might be important to trick the hot gasses into going left instead of right etc... very complex and we can't propose to understand how the Chinese factory was expecting this to work.
G
gslender wrote:Black_Penguin wrote:Wouldn't make a difference, the idea is to have the 'pulses' of exhaust gas enter the collector at equally separate times. The order that this happens in is unimportant.
G
i am no expert but i googled it.
as i understand, for the collector to scavange the right volume of gasses from each cylinder the pipes must be the same length to the collector.
i think if there is a big difference in pipe lengths the gas pressure in each pipe will vary due to temperature/expansion after combustion.
then the BERNOULLI effect of the collector will draw different volumes of gas from each pipe??
does that sound right??
Sounds about right. What you missed though was gslenders reply was positively dripping with sarcasm.
- Vehicle: Non MX-5
pezchops wrote:gslender wrote:Black_Penguin wrote:Wouldn't make a difference, the idea is to have the 'pulses' of exhaust gas enter the collector at equally separate times. The order that this happens in is unimportant.
G
I brought all this stuff up 4-5 pages back. Da Plane failed to understand. Then Da Plane attempted to explain fluid dynamics and even stuffed that up also. Then still wasn't able to tell us why these tuned length headers have different length primaries. Give up, he ain't listening or understanding. Chinese physics is different from normal physics. Non Chinese are too stupid to understand.
project.r.racing wrote:I brought all this stuff up 4-5 pages back. Da Plane failed to understand. Then Da Plane attempted to explain fluid dynamics and even stuffed that up also. Then still wasn't able to tell us why these tuned length headers have different length primaries. Give up, he ain't listening or understanding. Chinese physics is different from normal physics. Non Chinese are too stupid to understand.
I am Chinese and I don't understand.
Don't think Da Plane is chinese though! If he is, we collectively disown him right now, for being daft.
- Vehicle: Non MX-5
Haven't you read any of the posted in this thread?markwid wrote:project.r.racing wrote:I brought all this stuff up 4-5 pages back. Da Plane failed to understand. Then Da Plane attempted to explain fluid dynamics and even stuffed that up also. Then still wasn't able to tell us why these tuned length headers have different length primaries. Give up, he ain't listening or understanding. Chinese physics is different from normal physics. Non Chinese are too stupid to understand.
If he ain't Chinese, then he has alot of man love for them.
golden! If only forums had a "Like" button.
Loving reading this thread. I haven't read it until now. Can't wait til he tries to put those things on and finds that the welds are all over the flanges where the nuts need to go.
^wait so you aren't even going to install them yourself ?
Didn't you have a huge go at nearly all of us for not modifying our own cars... ?
- Regie
- Vehicle: NC - V8
emily_mx5 wrote:^wait so you aren't even going to install them yourself ?
of course not, he couldn't put a steering wheel boss together
- Pamex
booerns wrote:Don't be mean guys, it didn't even come with instructions... how was he meant to be able to figure out how something as complicated as a steering wheel works??
Give him a break. Steering wheels have advanced a lot, you know. A Chinese man with his math trickery worked out that round was better than square and unfortunately they haven't updated the instructions to help with the round ones yet.
- KevGoat
For entertainment...throw a flat bottom wheel in the mix...
Sent from my GT-P1000T using Tapatalk 2
