Disappopinted $2000 spend
Hjt
Re: Disappopinted $2000 spend
Postby Hjt » Wed May 29, 2013 9:01 pm
MX5 mania should know how to tune my NA8 than anybody else in Sydney
great people doesn't always mean great tuners of motor vehicles.
mexiegirl
Postby mexiegirl » Wed May 29, 2013 10:50 pm
True quote but in my mind there not great people either
Hjt
Postby Hjt » Thu May 30, 2013 1:07 am
let me just add this. this forum is sponsored by the company and they have a decent brand and reputation.
anything said will likely get back to them in due time
this being said, everyone can have an opinion ;)
bigmaxy
Postby bigmaxy » Thu May 30, 2013 10:59 am
I think it is important that potential customers have information available to help in their decision making processes when selecting where to spend their money.
This is mexiegirls story and I for one appreciate it being told. Others are welcome to post their own threads about the fantastics tunes they have received from mania is they wish.
To me the simple facts tell an interesting story.
Tuner A recommends ECU with options and tunes vehicle. Gets what appears to be good result from dyno but pings and runs badly.
Tuner A tells customer it is normal and to live with it.
Tuner B fixes problems with software within 10 secs and makes privability improvements and is very corteous.
To me it would appear that Tuner B knows how to tune successfully. Tuner A does not.
To me it would appear that Tuner B knows how to work with a customer and provide a good result. Tuner A does not.
mexiegirl
Postby mexiegirl » Thu May 30, 2013 12:05 pm
Thats what this forum is built on isn't it opinions, experiences and helping others
[quote="Hjt"]let me just add this. this forum is sponsored by the company and they have a decent brand and reputation.
this being said, everyone can have an opinion ;)[/
mexiegirl
Postby mexiegirl » Thu May 30, 2013 12:11 pm
Hey there Bigmaxy
Your excatly right and spot on, and yes was a good dyno result for 2 reasons (1) his happy dyno (generous reading) (2) he retard my cams heaps
There is a point that every one has missed though, Andy from Adaptronic is a legend and does have a good product. Also there is a guy on here that has also had a bad adaptronic experience from MANIA too he was more searching for help than having a bitch sesion like me.
bigmaxy wrote:I think it is important that potential customers have information available to help in their decision making processes when selecting where to spend their money.
OurCognitiveSurplus
Postby OurCognitiveSurplus » Thu May 30, 2013 2:53 pm
People need to be careful talking 'HP for $' and comparing turbos to n/a engines.
Yes, the horses come cheaper via a turbo, but you open cans of worms. No insurance. Can't pass inspection. Potential for defect notices. Can't resell etc. If you want to turbo and get full compliant paperwork, it's going to cost more than $3k.
At least with the n/a route, making the car appear stock is fairly easy (heat shield over the headers, stock airbox - done).
TL;DR - turbo v n/a is more complicated than just $ and horses.
NB8A - Twilight Blue
Postby Magpie » Thu May 30, 2013 3:33 pm
A lot of planning has to go into building an NA and you need to be consider each activity as how it fits in with the final product. First do you want a certain torque curve or do you want outright HP? What will be your final rev limit and how much time will it spend there? All these and many more, not to mention deciding who will be doing the head work etc. Do you go with an off the shelf modified head or give the job to somebody else? You need to have confidence in the person doing the work for you and they need to be able to advise, suggest, recommend and you need to be able to listen, ask questions and do research.
I guess these questions are the same for a FI build, but making a decision error could. It be expensive or limiting as it could be a NA build.
mexiegirl
Postby mexiegirl » Thu May 30, 2013 7:25 pm
Thankyou for your advice I feel better going down the n/a road now for all of your reasons
OurCognitiveSurplus wrote:People need to be careful talking 'HP for $' and comparing turbos to n/a engines.
zephyrus17
Postby zephyrus17 » Fri May 31, 2013 12:03 am
I haven't gone through the fancy engine work route, but I've gotten a 15kW gain from 65kW to 80kW. This is from a full exhaust change, doing a DIY CAI and changing timing to 14deg. Altogether, cost me around $1,500 (can't remember anymore). John Keen at Southern Hi-Tech did the dyno for me, and I put a lot of trust in him. When asked about how to get more power but staying N/A, he said it'll be another $3-4k, and only another 10 - 15 kW. So I decided that it'll be it from me in terms of power. It's just not worth it, me thinks.
Momo (aka 1990 white NA6)
mexiegirl
Postby mexiegirl » Fri May 31, 2013 11:00 am
Very true Zephyrus about the bigger dollars from here, I believe a good air intake is great value for $ too. I think the low pressure (through the firewall ones) are great, sound nice too. If the place that did your exhaust is performace savy maybe they could do what I did and spend $250 on an aluminium intake tube.
And yes trust is an important thing
zephyrus17 wrote:I haven't gone through the fancy engine work route, but I've gotten a 15kW gain from 65kW to 80kW. This is from a full exhaust change, doing a DIY CAI and changing timing to 14deg. Altogether, cost me around $1,500 (can't remember anymore). John Keen at Southern Hi-Tech did the dyno for me, and I put a lot of trust in him. When asked about how to get more power but staying N/A, he said it'll be another $3-4k, and only another 10 - 15 kW. So I decided that it'll be it from me in terms of power. It's just not worth it, me thinks.
Postby NitroDann » Fri May 31, 2013 11:22 am
ITT: People who haven't dríven a 200kw mx5.
Sean
Postby Sean » Fri May 31, 2013 11:59 pm
Glad it all worked out well for you in the end.
Seems you didn't need that wideband afterall?
zephyrus17
Postby zephyrus17 » Sat Jun 01, 2013 11:45 am
mexiegirl wrote:Very true Zephyrus about the bigger dollars from here, I believe a good air intake is great value for $ too. I think the low pressure (through the firewall ones) are great, sound nice too. If the place that did your exhaust is performace savy maybe they could do what I did and spend $250 on an aluminium intake tube.
I did both myself, so I wouldn't know what the shop price is. But the intake is simple, drill a hole and get some pipes from Bunnings, viola!
NitroDann wrote:ITT: People who haven't dríven a 200kw mx5.
Well, if I really, really wanted to, I could throw all my $ to get the power up. But at what cost? I could spend less money and get a car more powerful than that. And it would ruin the MX-5, in my opinion. Ultimately, to each their own.
Postby NitroDann » Sat Jun 01, 2013 12:48 pm
You would be hard pressed to spend less money and get a quickrr car however.
It isnt about power its about performance.
