How old is yr timing belt
gslender
Re: How old is yr timing belt
Postby gslender » Sat Sep 20, 2014 3:08 pm
It also may result in parting of money for unnecessary service maintenance
gslender
Postby gslender » Sat Sep 20, 2014 6:17 pm
manga_blue wrote:To install the cams I have to position both cams at their set points and not rotate them until the belt is on. I've done that a few times but I do remember that I started doing it when I had standard cams because they caught once and I almost bent the valves until I realised that I had interference at the valve rims.
You must have something non standard.
I've been able to check this of the following heads....
NA6 B6 Head - can rotate both cams with lift on both intake/exhaust, no interference.
NA8 BP05 Head - can rotate both cams with lift on both intake/exhaust, no interference.
NB8 BP4W Head - can rotate both cams with lift on both intake/exhaust, no interference.
I was able to inspect the NA8 and NA6 heads as they were off the engine, and with both valves open there was several mm of space between each valve. I have no idea how you'd get them to interfere so I can only assume magna_blue was extending the valves beyond the cam lobe profile.
The NB8 head was installed, but I could turn them with no resistance or hitting anything, so can only assume nothing cam into contact with either piston or valves.
The B6 and BP engines are both listed and confirmed by Mazda as non-interference - that means something and you can choose to ignore that and follow the "guidance" in the user guide book in the glove book and pay a mechanic every 5 years to replace the cam belt early before it needs replacing if you feel so inclined. Most folks who have no clue about how engines work are happy to pay mechanics to perform routine maintenance on their cars for all sorts of reasons - if you're convinced your saving yourself from "maybe damage" and that's worth paying for, then so be it. I frankly don't care as it's your money.
Fact remains, the B6 and BP engines are non-interference and nothing I've seen has yet to demonstrate otherwise. How you use that information in cam belt replacement is up to you - some will stick to their limited understanding of engines and follow the user guide, others who have a better understanding will choose their own maintenance schedule.
Let's leave it be at that hey?
Postby manga_blue » Sat Sep 20, 2014 7:10 pm
Can't see any logical reason why there's so much diff between your heads and my heads. No big deal, just strange. :?
I do know that original factory machining on mine were both pretty shyte, but not that shyte.
gslender
Postby gslender » Sun Sep 21, 2014 10:31 am
manga_blue wrote:Can't see any logical reason why there's so much diff between your heads and my heads. No big deal, just strange. :?
I'll try and take a photo so you can see, but there is no way the stock cams can push the valves out enough - if you see the angle and space between them you'd only get interference if you removed the springs and push the valve down/out much further than the cam lobe would.
Perhaps your memory is different, but on the 3 heads tested, no interference is what it seems to mean.
project.r.racing
Postby project.r.racing » Sun Sep 21, 2014 10:41 am
manga_blue wrote:
gslender wrote:Mine's a BP05 head with standard valves and seat heights. The cams in there now have lifts of IN 9.2mm/EX 9.6mm, versus 8.6/8.6 standard. IN and EX valves interfere by quite a long way, about 2mm, if I set one pair of EX valves to full lift and rotate the IN cam independently. To install the cams I have to position both cams at their set points and not rotate them until the belt is on. I've done that a few times but I do remember that I started doing it when I had standard cams because they caught once and I almost bent the valves until I realised that I had interference at the valve rims.
I think the situation could be safer with a BP4W head because it's high-ported and the valves sit a bit more vertical.
Are you saying the new cams make it non interference, or the old ones were?
stock BP-05 cams on an mx5 are 8.15/8.66.
96-98 323 ones were 8.30/8.89, with the exhasut camshaft having reduce duration of 9 degrees.
but then lift isn't the only thing that will cause contact, duration is a bigger factor.
gussy
Postby gussy » Sun Sep 21, 2014 3:34 pm
I don't understand why people are so relaxed about changing the timing belt and water pump. I always do it as scheduled on my cars. At least you can have confidence neither of them will fail and Murphy's law dictates it'll be in the middle of nowhere / at 1am / in the overtaking lane on the highway when it fails.
It's all good in saying that it's a non interference engine too but if the timing belt isn't done, then there could be a chance that the water pump could fail due to it not being changed on schedule either - and I know my missus rarely looks at the temperature gauge so the only indication that anything is wrong to her is when the engine seizes and grinds to a halt in plumes of steam - cheers love - new engine.
Best case scenario - you're stuck at the side of the road and you need to get a tow AND get the timing belt and water pump done anyway, so why not get it done earlier and avoid any unnecessary hassles? And if you're going to sell the car soon and don't want to bother doing it then I'm sure any prospective buyer would wonder where else you have skimped on servicing also and probably factor the job into his offer anyway.
aviper4u
Postby aviper4u » Sun Sep 21, 2014 10:20 pm
gussy wrote:I don't understand why people are so relaxed about changing the timing belt and water pump. I always do it as scheduled on my cars. At least you can have confidence neither of them will fail and Murphy's law dictates it'll be in the middle of nowhere / at 1am / in the overtaking lane on the highway when it fails.
+1
as previously suggested it's usually every 100,000kms OR ten years which ever comes first............ these are just conservative averages to reduce breakdowns,
for example;
carA short shifted at 2,000RPM
carB raced regularly
as everything is spinning more carB would fail first, similar to most motorcycle engines and service intervals compared to most cars
gslender
Postby gslender » Mon Sep 22, 2014 9:49 am
All true, but no different to fuel pump
Postby Mr Morlock » Mon Sep 22, 2014 10:03 am
Gslender you are just stuck in a groove everyone seems to get except you. There is no recommendation by MAzda or probably any other maker to replace fuel pumps at service intervals. Feel free to ignore replacement of timing belt and usual precaution of water pump at 100k intervals.
project.r.racing
Postby project.r.racing » Mon Sep 22, 2014 10:09 am
the recommendation is 100K or 5 years. whichever comes first.
i guess if you are gonna run with mazda recommendations, then maximum is 5 years life.
gslender
Postby gslender » Mon Sep 22, 2014 10:16 am
Mazda recommends checking tyre pressures before driving, do you do that? Every time? Without fail?
gslender
Postby gslender » Mon Sep 22, 2014 10:43 am
Mr Morlock wrote:Gslender you are just stuck in a groove everyone seems to get except you. There is no recommendation by MAzda or probably any other maker to replace fuel pumps at service intervals. Feel free to ignore replacement of timing belt and usual precaution of water pump at 100k intervals.
The official Mazda workshop manual for a 1990 MX5 only lists oil, coolant, spark plugs and filters as R (replace) items and the timing belt is the only other item listed to be replaced at 60,000 miles (it does not specify time so technically, according to Mazda you could run indefinitely as long as you don't go over 60,000 miles traveled).
I've just checked these facts against the PDF that I have on the 1990 Mazda MX-5 Workshop Manual.
Can you honestly imagine owning the vehicle for 15 years and only following that guide. Do you really think your car would be in good running condition and not at risk of regular failure??
To any half intelligent person (with a mechanical background) it would be seen that these are provided for "guidance" - they are not predetermined facts.
The facts, (for those that like to base their decisions on truth instead of made up stuff) is that the timing belt will eventually fail, and when it does, that act itself will not cause any damage - the engine is non-interference and this means that the valves, will not in their normal use, hit anything if the belt fails to align the camshafts to the crank.
Will the belt (when snapping) cause other damage? - it is possible though unlikely (no more or less than any other component that when failing can cause damage etc). There are heaps of things that can cause damage to the engine when they fail (and they will).
Will the belt snapping be inconvenient. Yes. More inconvenient than a failed fuel pump. No. More risky. No. Exactly the same.
These are the facts.
Anything further is just opinion and speculation.
JBT
Postby JBT » Mon Sep 22, 2014 10:45 am
project.r.racing wrote:the recommendation is 100K or 5 years. whichever comes first.
Mazda recommends 100,000 kms - no time is mentioned in the owners manual.
Postby manga_blue » Mon Sep 22, 2014 11:00 am
The Maintenance Table starts on page 102 in the NA Owners Manual, attached. Make of it what you will. :lol:
https://dl.dropboxusercontent.com/u/890 ... Manual.pdf
speed
Postby speed » Mon Sep 22, 2014 11:08 am
Mr M, I believe that Grant is trying to educate the way in which you view maintenance.
You have stated your own opinion on the matter and how you will do what the book says re service maintenance. Ok.
Grant has given examples of other parts that can cause a car to come to a sudden stop and yet some of those parts are not mentioned in the service manual.
I believe that grant has proved his point.
What you do with the info is your own business.
Surely you must see the side where Mazda is out to protect themselves more than explain tech stuff in detail. And if mazda's service guidelines were spot on it must be changed at 100k or 5 years, then why is this service period identical to the majority of other inline four cylinder engines?
It's a guideline. That's all.
