NB8B CAI
bootz
Re: NB8B CAI
Postby bootz » Mon Jul 04, 2011 9:09 pm
Ah, so you did send that rabbit down the hole. Very encouraging that you had +ve pressure.
Thinking of doing the same but on the coldside.
Have to dig my own hole unfortunately. Not particularly keen on losing a foglight either. :lol:
Hellmun
Re: NB8B CAI
Postby Hellmun » Mon Jul 04, 2011 9:53 pm
I suppose I could re-seal it again and hook up a boost monitor to the datalogger. Would be interesting to prove how much airflow there is at speed from the foglight. It's much less proven than the firewall CAI method which isn't available to our ABS cars. I'll have a look to see if I can find an appropriate cheap sensor, could re-use it for the turbo.
Re: NB8B CAI
Postby NitroDann » Mon Jul 04, 2011 11:49 pm
use ANY map sensor and just a datalogger set to 0-5v and compare still ambient engine off voltage to driving at speed in neutral voltage. wont tell you psi like I can but it will tell you relative pressures.
