SP ENGINE MISS AT 4-4,500 RPM
- bigdog
- King of the kennel
I'll put up my hand to run the GB Sean. PM me Steve's number and I'll post an expression of interest in the For Sale column and see how many we can get interested.
i have a plastic Bosch BOV from an rx7 that i haven't got around to fitting yet. Apparently they are good to around 12psi. i was planning on using this but now I'm wondering whether it's likely to end up failing (assuming it hasn't already... it was bought from a wreckers) like many of you guys have reported with the other Bosch BOV's.
a bit of guidance from the experienced turbo guys would be appreciated here.... it will have a big influence on whether i go in on this turbosmart group buy or not.
cheers.
cheers.
Fatty wrote:i have a plastic Bosch BOV from an rx7 that i haven't got around to fitting yet. Apparently they are good to around 12psi. i was planning on using this but now I'm wondering whether it's likely to end up failing (assuming it hasn't already... it was bought from a wreckers) like many of you guys have reported with the other Bosch BOV's.
cheers.
Fatty expect the Bosch one to fail. While they give a 'rating' of how many psi they can handle, regular 'heavy' use can bugger them up anyway regardless of what psi you're using. They're plastic! You've only got to replace one or two Bosch ones and you've pretty much paid for one of these TurboSmart ones. I went through 2 of them on the ET years ago (in quick succession) before I woke up
yeah i was thinking the same thing... and it's a second hand one to start with so chances are it's already shagged
Just thought I'd follow up on this one again folks
I've had the SP for about 7 weeks now, and discovered something interesting last week. When I test drove mine, I ran through all the scenarios I've read about which seem to cause this bucking effect that everyone talks about, but could not replicate it on the test drive. I didn't notice in the first 1500kms of ownership either. Then I fitted one of the aforementioned TurboSmart Kompact BOV's. I played around with the settings on this for a while, and now have it set to full hard.
Now here's the interesting part.... I had noticed that the air box had seemed a bit loose, so decided to tighten the spring loaded bolt in the bottom of the airbox. In another thread on here in the last couple of weeks, Garry mentioned the airbox needing to be able to move about with the engine movement - makes sense. Since I tightened the bolt in the bottom of the air box, I had discovered some of this bucking effect, but didn't connect the two. I was thinking that the oxygen sensor might be playing up, as it also seemed to be running rich, and throttle response was quite poor. Long story short, while pulling my hair out over this, I decided that the symptoms were similar to what I had experienced in another car, where the wiring to the air flow meter had been damaged. I decided to check the connection to the afm, and while it didn't take much, it pushed onto the afm fitting by a small amount. Since then, the car has run like a dream!!
I also backed the bolt in the bottom of the airbox off a bit, and made sure that the airbox has some movement to accommodate engine movement. My theory is that because the airbox was fairly tight, the engine movement pulled on the wiring loom to the afm (because the afm was not moving as it is attached to the airbox) and so compromised the connection of the plug to the afm. The afm is very sensitive to voltage change, so I think this may just be the cause of some of the SP "issues". It's certainly worked for me so far
