Cranks, no start nightmare
Re: Cranks, no start nightmare
Postby 93_Clubman » Mon Mar 28, 2016 5:22 pm
Great that you've got it running again!
Todd B wrote:I understand why the wrecker ecu didn't work in my car. I didn't have the right key for it.
IIRC, thought it was NB8B onward that required matching key.
Postby 93_Clubman » Mon Mar 28, 2016 11:47 pm
From a quick look it looks like at least some NB8As did to.
Postby hks_kansei » Tue Mar 29, 2016 8:47 am
Can confirm NB8A did have the immobiliser.
Mine's a 99 build and has the OEM sticker on the sunvisor carrying on about immobiliser and chips in the keys etc.
Todd B
Postby Todd B » Tue Mar 29, 2016 9:17 am
FWIW, my car is an April 98 build, and I just have a standard steel key with no chip or battery in it.
Postby manga_blue » Tue Mar 29, 2016 1:32 pm
My personal opinion is that immobilisers are so evil that their malevolence spreads from car to car, even infecting cars that never had immobilisers.
Glad you got it going again, Todd. :D
Postby 93_Clubman » Wed Mar 30, 2016 11:51 am
Todd B wrote:FWIW, my car is an April 98 build, and I just have a standard steel key with no chip or battery in it.
Given your using a standard steel key, does the ignition key barrel on the steering column have a black ring around it? If it does, this is the sensor for a chipped key, in which case suggests a JDM ECU may have been swapped into your car to get around the key/immob/ECU compatibility issue. If so, this might explain why the ECU from the wrecker wouldn't work as it probably would have been an ADM ECU.
Todd B
Postby Todd B » Wed Mar 30, 2016 9:43 pm
I'm going to say "no" to a black ring around the ignition barrel. I just took a look at it, and there's the black trim ring that says, "Acc" and "On" on it, but the actual lock cylinder is silver.
Postby hks_kansei » Thu Mar 31, 2016 8:54 am
Mine's the same as Todd describes.
I can't remember though if there's anything behind the column trim, I didnt take note last time I had it off.
Postby 93_Clubman » Thu Mar 31, 2016 11:38 am
Todd B wrote:Except that the immobilizer light was on.
Given above, guess this begs the question is the immobilizer factory or aftermarket.
Todd B
Postby Todd B » Thu Mar 31, 2016 2:21 pm
The way I figure it, my car does not have a factory immobilizer. But the car that I got the ecu must have had one, and so it was looking for a signal from the key or ignition switch. Since that wasn't there, the immobilizer light was on. I can't figure out though why my car even has an immobilizer light! Perhaps it is just some standard equipment that other markets get and Oz didn't.
