Megasquirt I 12x12 tables big enough (ITBs)
gslender
Re: Megasquirt I 12x12 tables big enough (ITBs)
Postby gslender » Wed Sep 12, 2012 3:40 pm
Si.G wrote:Could I drop a MSII board in my MSPNP I ?
Yes, but check with the DIY guys as they can outline what else is required.
G
Si.G
Postby Si.G » Sat Sep 15, 2012 3:47 pm
checked with DIY auto tune guys. They were very helpful. Basically the MS2 daughter board will go straight in there, only thing I need to look at is the coil outputs, they are the opposite way around on the MS2, so with out modifications my spark will be firing on the exhaust stroke. Not a big deal, there are a few ways to fix it, all are pretty easy.
The board is ordered and I have been having a look at the new features on MS2. MS2 is a big step forward over MS1, so should be cool and if I really need it I can have a 31x16 fuel table and a 23x16 spark table by using the table switching feature.
Thanks for all the input guys. Thought it was worth posting this up, just in case anyone else was wondering if you can upgrade you MSPNP 1
Si.
NA6 B6T
gslender
Postby gslender » Sat Sep 15, 2012 11:14 pm
That's certainly cool to know. Also, your existing MS1 tune can be loaded into TS and upgraded to MS2.
How flexible is Megasquirt stuff hey ;)
G
Si.G
Postby Si.G » Sat Sep 15, 2012 11:40 pm
gslender wrote:That's certainly cool to know. Also, your existing MS1 tune can be loaded into TS and upgraded to MS2.
G
Didn't know TS would upgrade the tune, that makes it even sweeter. Love the megasquirt stuff, I am glad I did not jump to buying a another ECU.
NA6 B6T
