Maximum speed
Re: Maximum speed
Sorry, that should have read cubed root of velocity.
Re: Maximum speed
StillIC wrote:Sorry, that should have read cubed root of velocity.
Let's work these figures backwards
Corvette ZR1 = 450kw and 330km/h top speed
So at 110km/h it would only need about 17kW (1/27th)
220km/h would require 133kw (8 times 17kw)
Sound about right?
- NitroDann
Re: Maximum speed
In not sure what ive done here. Are you saying you need 4 times or 8 times more power to do 2 times the speed?
Re: Maximum speed
Yep, sounds about right. But remember there is an 'overhead' in the power requirement to turn and distort the tyre rubber. It is a pretty linear 'curve' when plotting power V velocity, however....a small percentage of power at 330km/h, a much larger one at 110km/h.
Read it again Dann. Twice the speed = 8 times the power to overcome aero drag.
If 80kW ATW gives you 200km/h (say, my Celica), you can do 100km/h with just 10kW ATW. And you therefore need 640kW ATW to do 400km/h....which is about what a Veyron has.
Scott
Scott
- NitroDann
Re: Maximum speed
yep your right. Seems I was off by a ^2
Thankyou.
Thankyou.
- NitroDann
Re: Maximum speed
So....
A friend of a friend of mine who apparently has a black and white na6 recently sent me a few videos he says he took on his phone regarding the 185kmh max speed question.
He didnt have a long enough road but his car goes from 160-170 in about 2 seconds so it wasnt having any issues at all. It looked like the needle was just going to fly past 180.
- MX5-SP
Re: Maximum speed
NitroDann wrote:So....
Your friend used his phone to video his speedo at 170kph!!...
Snow White: Torsen 3.9 LSD, A/Sway Bars, R/Bar Plus Clear Reflectors!
- NitroDann
Re: Maximum speed
Why? A phone is easier to tape to the dash than a camcorder is.
Re: Maximum speed
Logged a 193.4kmh before turn 1 at PI yesterday with a 15kmh tailwind and everything else much the same as usual. That's 7kmh better than anything previous and the first time I can recall having the wind behind us like that. 5th gear took the car from 179 to 193 when usually it gives me no speed increase at all. Nice to see the speedo over 200 too
Certainly demonstrated the impact of wind drag. Ultimately it made little difference to lap times since you've got to beat upwind out of the Southern Loop and Siberia anyway.
It was interesting to apply some of StillIC's formulary. Using Dynamic pressure = 1/2 air mass x velocity squared only gives you 0.22 psi at 180kmh and 20degC. So just a trumpet sticking way out the front really would give you buggar all boost - you must find a high pressure zone somewhere on the car.
- greenMachine
Re: Maximum speed
manga_blue wrote:Certainly demonstrated the impact of wind drag. Ultimately it made little difference to lap times since you've got to beat upwind out of the Southern Loop and Siberia anyway.
Nope, it did make a difference.
Think about it. Drag increases as the square(?) of speed, that means you are using more power at 200kmh to increase 1kmh, compared to 100kmh. So if the wind is behind you at the highest speeds, you will be going faster (lapping quicker) than if the wind is behind you on slower parts of the circuit. This is magnified by the length of the PI straight, and the high entry speed.
If your lap times did not reflect this, there was something else at work offsetting this gain.
Re: Maximum speed
I'm afraid you're right, GM. I did a PB there late in the day. I would have preferred to put that down to great driving rather than wind assistance.
Averaged about 5 kmh faster than the old PB down the main straight, 2 km slower from Southern Loop to Honda and 2 kmh faster upwind from Siberia to Lucas, probably because of a bit of shelter from the ridge.
