NB8B CAI
Re: NB8B CAI
Postby 93_Clubman » Wed Jun 29, 2011 1:33 am
bootz wrote:Wiring doesn't need to be cut.
Said it needs to be extended, unless you're saying there's enough factory MAF wiring standard to extend to the area between the throttle body & the area behind the driver's side headlight on a RHD. There certainly isn't on all MX5s.
bootz
Re: NB8B CAI
Postby bootz » Wed Jun 29, 2011 2:28 pm
The wiring is not a big issue whether you use existing or extend it.
Does anyone think cutting a hole behind the headlight to match the one on the hotside is not a good idea. :?:
That is, aside from the pain of carefully grinding/cutting a hole to match the other one, I thought it might contribute to a CAI coldside.
Re: NB8B CAI
Postby 93_Clubman » Wed Jun 29, 2011 4:55 pm
bootz wrote:Does anyone think cutting a hole behind the headlight to match the one on the hotside is not a good idea. :?:
That seemed to be Sliq's point:
sliq wrote:i know on the hot side there's a hole on the chassis which allows you to bolt the down pipe and the airbox. that hole might be missing on the cold side. it's definitely a hole you don't want to be cutting out =\
Re: NB8B CAI
Postby NitroDann » Wed Jun 29, 2011 5:36 pm
Why the hell not?
bootz
Re: NB8B CAI
Postby bootz » Wed Jun 29, 2011 8:20 pm
I'm with Dann, why the hell not. Symetrical holes in the same position, only one is on the coldside.
I want to do it and I don't see any reason not to. :?:
Re: NB8B CAI
Postby 93_Clubman » Thu Jun 30, 2011 3:00 pm
bootz wrote:I don't see the big problem in cutting a hole in the coldside (behind the headlight) to replicate the hotside one. It's not in a place you would notice and I want to box it in if possible just in case the police wish to look in the bonnet.
bootz wrote:I'm with Dann, why the hell not. Symetrical holes in the same position, only one is on the coldside.
In the absence elaboration from Sliq on reason/s, it sounds like you've already made up your mind & aren't worried about potential illegality (depending on jurisdiction), which may or may not be well founded.
Cutting the hole aside, according to forumites that have shortened the overall intake length by doing away with the engine crosspipe & fitting a pod filter & MAF to an adaptor which attaches to the throttle body, there's improved responsiveness, but loss of torque. May be try this first to see what you think before going further.
aviper4u
Re: NB8B CAI
Postby aviper4u » Thu Jun 30, 2011 3:47 pm
93_Clubman wrote:Cutting the hole aside, according to forumites that have shortened the overall intake length by doing away with the engine crosspipe & fitting a pod filter & MAF to an adaptor which attaches to the throttle body, there's improved responsiveness, but loss of torque. May be try this first to see what you think before going further.
recall reading something about the loss of torque as there is less "air volume" though then what about the super exxy autoexe intake soley on the cold side????
after looking into all this it all just seems to much effort for minor gain might as well just get a turbo kit OR supercharger kit if you want a "real" gain.
just my OP
Re: NB8B CAI
Postby 93_Clubman » Thu Jun 30, 2011 4:42 pm
recall reading something about the loss of torque as there is less "air volume" through then what about the super exxy autoexe intake soley on the cold side????
Imagine it's similarly affected, but some have been happy with the improved response, & I think top end, so depends what you want.
Re: NB8B CAI
Postby NitroDann » Thu Jun 30, 2011 7:56 pm
My intake was cheap as it comes and makes half a pound of boost at just 50kph. WELL worth it for 30 bucks.
bootz
Re: NB8B CAI
Postby bootz » Thu Jun 30, 2011 9:43 pm
just my OP
1. Possibly, plenty of opinions by people who love their coldside CAI.
2. Right, Super exxy Autoexe uses only headlight air (It does isolate the filter from engine air so is true CAI - see Dann's main point)
3.I wanted opinion if there was anything important under and behind the RHS headlight (Oh no, don't cut there, a massive steering component..) I cant believe I am the first to think of it. :?:
4. Am waiting on a OBD scan guage so I can measure intake temps before and after each change.
5. If it all cocks up then its back to stock and I have had a bit of fun. Total cost about $50, and maybe a small hole behind the headlight, trivial :evil:
Re: NB8B CAI
Postby 93_Clubman » Fri Jul 01, 2011 11:27 am
bootz wrote:3. I wanted opinion if there was anything important under and behind the RHS headlight (Oh no, don't cut there, a massive steering component...)
General questions usually get a general response.
bootz
Re: NB8B CAI
Postby bootz » Fri Jul 01, 2011 11:46 pm
sliq wrote:i don't think you get the optimum gain if it was cold side.
Sliq's opinion was quite definite, I was wondering why. Perhaps we will never know. :roll:
Hellmun
Re: NB8B CAI
Postby Hellmun » Sun Jul 03, 2011 12:15 am
I think there's actually a larger gap behind the NB8B headlights and the NB8A on the hot-side. I remember Irwin8er had more trouble getting room for his CAI than I did and we compared the cars side by side at the time. That was over 4 years ago though so I can't remember specifics anymore. He wound up skipping the gap behind the headlight and just running piping down along the chassis rails to the wheel well for a pick-up. My CAI uses a 2.5" rubber intake off 87 JE camira down past the headlight to a PVC elbow on the foglight hole. That then runs into a sealed box with a modified K&N typhoon intake pipe run into with the K&N pod filter. I know when it was sealed perfectly it ripped out two self-tappers due to the air pressure so I wound up gaffa taping the whole lid as a quick-fix at the track....then kept putting off doing it properly as it'll need to be re-designed for the turbo anyway. For me though the rubber sealing around the K&N intake has gone too hard and opened up a gap now.... so my pressure should be down.
bootz
Re: NB8B CAI
Postby bootz » Mon Jul 04, 2011 1:09 pm
Hellmun wrote: My CAI uses a 2.5" rubber intake off 87 JE camira down past the headlight to a PVC elbow on the foglight hole.
Where past the headlight, not down the hole?
Hellmun
Re: NB8B CAI
Postby Hellmun » Mon Jul 04, 2011 8:48 pm
The hole is behind/under the headlight, here's a little picture which gives a better idea but to show you properly will have to wait until the weekend.
Users browsing this forum: Bing [Bot] and 3 guests
