Subaru Upper Engine Cleaner review...
Dweezle
Postby Dweezle » Tue Dec 29, 2009 12:35 pm
I recently run a can of this stuff through my NA6.
Clouds of white smoke and all seemed to go well.
Only prob is now every 2nd or so time i cold start the car,
Its like a fire extinguisher coming out my exhaust.
Lasts until the car warms up.
Is this at all normal? Could the chemicals have eaten my head gasket or something?
Would it be at all possible for some of the carbon deposits to get stuck between the pistons and bore??
Its wierd in that it doesnt do it every time i start the car, and it usually takes about 20 seconds after it fires up then just blumes of white smoke.
Just a lil concerned now :?
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby Okibi » Tue Dec 29, 2009 1:30 pm
Sounds like valve stem seals.
Steampunk
Postby Steampunk » Tue Dec 29, 2009 2:06 pm
It might take 100km or so to show up, but check the oil (under oil cap) for white residue which denotes coolant in the oil, vice versa with oil in the radiator.
Hopefully its just left-over cleaner.
I ran this in my Festiva a couple weeks ago (148,000km), and its fine.
Dweezle
Postby Dweezle » Tue Dec 29, 2009 3:03 pm
Thanks guys..
I've read up a little on valve stem seals and the symptoms of dodgy ones very much match my problems..
I will check my oil cap and coolant, thanks red.. See what's going on there..
Jeremy Clarkson
Steampunk
Postby Steampunk » Tue Dec 29, 2009 4:55 pm
Not sure if it's part of the directions on the can, but my mate (who uses this all the time at his work) was instructed by Subaru that after application, to drive it pretty hard, ie. rev the engine high and often.
Did you do this? or have you dríven it fairly gently since?
You gotta be cruel to be kind :wink:
Postby Okibi » Tue Dec 29, 2009 5:35 pm
1red5 wrote:...was instructed by Subaru that after application, to drive it pretty hard...
Must be more margin in gear boxes than engine cleaner. :twisted:
Steampunk
Postby Steampunk » Tue Dec 29, 2009 7:44 pm
8) yeah probably.
But my mate did use this as a cheap, but effective, fix for a potentially VERY expensive problem that some Peugeot's have.
Forgot which model Peugeot (I think its most diesel passenger cars), but they have some sort of air injection something-or-rather in the exhaust manifold/part of the head to help reduce emissions/pollution.
This system gets clogged up and shows a warning light on the dash and fault codes on diagnosis. Car still runs fine.
Peugeot's S.O.P. to fix this is to remove the head :shock: , and do a thorough manual clean and replacement of affected parts.
Instead of doing all that, my friend suggested he run through one or two cans of this stuff ..... voila!
Postby Regie » Mon Jan 04, 2010 12:51 pm
ran a can of this on my car.. wow made a difference, runs a lot smoother and feels like its got a tad more go
gobsmax
Postby gobsmax » Mon Jan 04, 2010 1:14 pm
Dweezle & Regie, where did you get a can and how much was it?
Red '91 NA6 (R.I.P.)
Black '07 NC PRHT (R.I.P.)
Gold '98 NB8A (SOLD)
Soul Red '15 ND 1.5 GT
tuned_to_fly
Postby tuned_to_fly » Mon Jan 04, 2010 1:16 pm
gobsmax wrote:Dweezle & Regie, where did you get a can and how much was it?
Any Subaru parts department will sell it and its around $20 if I remember correctly.
Postby Regie » Mon Jan 04, 2010 2:12 pm
yep any suby spare parts dealer. i got 2 cans for $37
acidkid
Postby acidkid » Mon Jan 04, 2010 5:43 pm
did a can in my dunno if i did it wrong or something but i think it did more harm then good....
Silver SP
NMX516
Postby NMX516 » Mon Jan 04, 2010 10:20 pm
acidkid wrote:did a can in my dunno if i did it wrong or something but i think it did more harm then good....
Why, what happened?
acidkid
Postby acidkid » Mon Jan 04, 2010 11:52 pm
Why, what happened?
Idling higher then usual so had to turn the idle down and just feels abit weird, driving wise didn't feel too different
Silver SP
SKYHI
Postby SKYHI » Fri Jan 08, 2010 10:52 am
Mazda/Miata Technical Service Sheet for the "Top Engine Cleaner".
http://www.miata.net/garage/tsb/s004_93.html
Paul.
Users browsing this forum: No registered users and 83 guests
