Advancing ignition timing to 14deg BTDC iz goooood
Steampunk
Postby Steampunk » Sun May 25, 2008 9:03 am
Sasso wrote:
Now I'm confused. Turning the CAS is what you're meant to do, and he turned it the right way by the sounds of it.
LOL... Sasso, we are talking the same language but just a different dialect. :)
What I meant was IF you turn the CAS WITHOUT jumping the TEN & GND terminals. THIS does nothing.
Agreed? :wink:
Noodle
Postby Noodle » Mon Nov 03, 2008 1:03 am
Hey just adding my 2c.
I did this to my NA8. It seemed to lose low end power when adjusted to 14 degrees BTDC. 12 degrees seems to be the sweet spot for my car.
I'm running BP Ultimate 98 and I reckon response when accelerating out of a corner is better now.
grump
Postby grump » Mon Nov 03, 2008 4:29 am
I got Graemebc (forum member and neighbour) to do mine, seemed a lot better right through the whole range, but 91octane seems to be the best fuel to get it running smoothest.
Noodle
Postby Noodle » Tue Nov 04, 2008 1:00 pm
grump wrote:I got Graemebc (forum member and neighbour) to do mine, seemed a lot better right through the whole range, but 91octane seems to be the best fuel to get it running smoothest.
Which engine do you have?
bensale
Postby bensale » Tue Nov 04, 2008 1:28 pm
I finally got around to getting a timing light and doing this a while ago, it definently makes a difference.
I ran 12 degrees on 91 octane for a while while petrol was more expensive, the car felt a bit torqueier. Now petrol prices are down a bit i'm running 14-15 degrees on 98. The car feels livlier and more responsive down low. Definetly worth doing
www.othersideproductions.com
CheyneX5
Postby CheyneX5 » Tue Nov 04, 2008 1:38 pm
hey ben, would you mind coming over to mine one weekend to help me with this? i dont have a timing light and i dont trust my self to be fiddling too much, ill shout you a coffee :D
90' NA6 - Classic Red
bensale
Postby bensale » Tue Nov 04, 2008 1:50 pm
Sure, sounds good :D
Anytime after November 17 as thats when my exams finish. Its not too difficult, it only takes a minute or two.
