More Bling
CT
Postby CT » Thu May 10, 2007 6:36 pm
By the look of the alternator windings, it might be worth pulling it apart and cleaning it prior to putting it back in the car - looks like there's a fair bit of metal polish residue in there which might affect its operation.... 8)
AJ
Postby AJ » Thu May 10, 2007 9:04 pm
Okibi & UA are OCD's :roll: :lol:
XMX5 Rogues
Postby Okibi » Fri May 11, 2007 2:05 am
Postby Okibi » Fri May 18, 2007 1:28 am
Postby Okibi » Sat May 19, 2007 9:14 pm
sabretooth
Postby sabretooth » Sat May 19, 2007 9:44 pm
I had the same issues with getting the holes for the radiator fan to line up on the radiator. I ended up just not putting the screws back into those holes.
zoomzoom
Postby zoomzoom » Sun May 20, 2007 2:26 am
I think he was trying to point out that he had to trim back the fan mounting to allow access to the oil cooler pipe.
That rad is HAWT!!! was looking at them recently, only dreaming though... :cry:
Postby Okibi » Sun May 20, 2007 9:52 pm
Considering PWR have a good reputation the twincooler is a bit of a balls up.
NONE of the holes/brackets were really in the right location.
I don't mind doing some modification, but I can see how someone looking at a \"bolt in\" solution would get really pissed off.
No wonder people are always complaining that mechanics take longer than expected to install a part, there's always some sorta stuffing around to make things fit.
Even the bolts to mount the fans were too long to use.
I had to cut my fan mounts a bit because I have the front sway brace.
sabretooth
Postby sabretooth » Mon May 21, 2007 9:49 am
Yeah, to get around the bolt length issue, I had to also put a nut on the bolt so that they wouldn't go all of the way in. Shocking quality control.
Postby Okibi » Tue May 29, 2007 2:49 am
Boags
Postby Boags » Tue May 29, 2007 3:44 am
Holy mother of christ! That is VERY impressive Dave! Noice. 8) :mrgreen:
lowmiata
Postby lowmiata » Tue May 29, 2007 7:24 am
has the car had a nose job recently?
EVI15 1998 to 2008
Bevan
Postby Bevan » Tue May 29, 2007 10:33 am
:shock: *Jaw Drops*
That is fantastic Dave! Congrats. :D
lowmiata wrote:has the car had a nose job recently?
Looks like it. Now has an NB8B nose. 8)
Juffa
Postby Juffa » Tue May 29, 2007 10:46 am
That engine bay is a work of art Okibi 8)
sabretooth wrote:Yeah, to get around the bolt length issue, I had to also put a nut on the bolt so that they wouldn't go all of the way in. Shocking quality control.
Yeah, my PWR radiator fan mounts didn't line up either. One fan is held at three points because of it. Then there is the plastic drain plug that refuses to come out.
But the best was yet to come. In the month after the I received the radiator PWR sent a number of items that I had not ordered. It got to the point where I told Jennifer to refuse to accept delivery from the courier. It took at least three phone calls to sort it out.
J
bigdog
King of the kennel
Postby bigdog » Tue May 29, 2007 11:06 am
WOW!! That is sweet Dave! Now all you need is some more decals for the windscreen - there's a few spots of clear glass left there :P :lol:
