More KW.
pcmx5
Postby pcmx5 » Wed Nov 15, 2006 11:14 am
jules wrote:Peter,
Sounds interesting. I'm really happy that you have achieved such a satisfying result.
Jules
Thanks Jules, I am rapt. I was a bit concerned that I would stuff up a car that was already good, but that is certainly not the case.
For me and what I do with the car it was also a fairly big investment and I initially debated that as well.
Now I reckon it was money well spent!!!
Peter.
Babalouie
godfather of saké
Postby Babalouie » Wed Nov 15, 2006 11:20 am
pcmx5 wrote:From what Babalouie said(if I haven't misinterpreted it) his slightly wilder cams specifify the factory settings anyway.
Yeah that's right. Tomei recommends 110/110 cam timing which is exactly what you get if you simply bung in the stock cam wheels.
I put in the adjustable gears anyway (at the stock position) but given that the cams give a nice even spread of torque, I've never been tempted to muck around with it (it would also require effort and I can't be bothered) :D.
glen73
Postby glen73 » Sun Nov 19, 2006 11:23 am
Anthony is King, All hail Anthony :)
when he tuned my car he kept telling me how much he loves working with this motor.
Rob E
Postby Rob E » Sun Nov 19, 2006 12:11 pm
Babalouie wrote:
pcmx5 wrote:Babalouie,
You have probably explained this many times before but what cams/ ECU are you using?
Peter.
I got the Tomei "Pon"cams, installed at the stock 110/110 timing:
http://www.tomei-p.co.jp/_2003web-catal ... a8_en.html
The ecu is stock, with just a simple Apexi SAFC piggyback/interceptor.
My power gain from the cams alone wasn't quite that dramatic, 8rwkw. But if I look at my dyno chart from before I fitted and tuned the SAFC, it was 74rwkw, same as you, so yeah a 16rwkw gain from cams and ecu is pretty similar to your results, except you got a touch more of course :)
The Tomei's look like a good option for an easy 10hp on the stock ECU 8) for around 1k all up they would be a nice addition to the normal Int/Header/Ex mod.
Babalouie
godfather of saké
Postby Babalouie » Sun Nov 19, 2006 12:55 pm
Rob E wrote:The Tomei's look like a good option for an easy 10hp on the stock ECU 8) for around 1k all up they would be a nice addition to the normal Int/Header/Ex mod.
Yup....87rwkw on the stock ecu on my car, 90rwkw with the tuned piggyback turned on. So yes it works very well, maybe a tiny little bit "cleaner" when tuned but not a big difference. And on a stock ecu I reckon the gain's more like 10rwkw.
