SE turbo, how much pwr?
CT
Postby CT » Sat Sep 09, 2006 11:38 pm
irwin83r wrote:soo... no one has really had a stabb at it yet?
Maximum rear wheel kilowatts for a SE turbo??
just at a stab with the standard turbine, manifolds. everything else over cooked would achieve.....? 200rwkw???
Flyin Miata have a 270whp car. It has had the $$ spent on it to do that HP. How long will it last really depends on the tuner and how good a job they've done on the maps. Not to mention, what pure $$ they've put into the engine.
It's boost, if you run 25 psi, it will probably make 200rwkw. How long it lasts, is up to you...... 8)
irwin83r
Postby irwin83r » Sun Sep 10, 2006 11:08 am
so how much power are the Race SE's making??? i thought the guys from mania said around 180rwkw?? :shock:
and thats built for prod sports so it would have standard turbo and manifolds, everthing else changed though. :?
or are they calling it an SE but making an mock SP :lol:
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Sep 10, 2006 11:15 am
There are no SE race cars running yet.
The 2 Turbo cars are SP replicas.
Nicks car runs about 140Kw.(for Class C)
Brians car runs about 180kw.(for Class B)
The Mania car is also a SP replica...they are planning to run class B so it will also be about 180kw.
My car will be the first (genuine)SE race car...I am aiming at about 130kw to fit me in at the top end of Class C.
irwin83r
Postby irwin83r » Sun Sep 10, 2006 11:26 am
ahh now that makes more sense. :lol:
so if its a mock SE i build then class C is where im heading?
thats all good. should be a better progression from supersprints. :)
