I am still confused!
Has it been an issue with any Aussie SE's yet and why is the expansion a problem?
More air can't be bad can it?
SE Owners - check out your intake pipe!
AJ wrote:well yeah pinkie, if that pipe pops, there'll be a world of trouble for that engine & it's turbo
I had to replace the rubber hoses (similar material to radiator hose) on my modified MX6 turbo with mandrel bent steel pipes. The problem was the rubber hoses were expanding at full boost and were costing a psi or two.
Stupid here originally didn't get bead welded on the edges of the pipes and they got blown off under boost - always the hardest one to get to and when I was the furtherest from home. The car wouldn't run below 4000rpm and each time resulted in a stall an a flat tow home.
Made a brilliant noise when it happened though
- PT
I too had that happen with mine... Did make a good sound, but the first time it did I freaked not knowing what it was.
Fortunately for me it was the clamp on the throttle body boot had let go at about 11psi.
Loved that car!
Loved that car!
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- Alf
AJ: You're probably right about it having been weakened by previous overboosting, kinda like a balloon that you've blown up & let down a few times. If it pops off, I can't imagine it causing any damage to either engine (which would see no boost) or turbo (which would see no backpressure). Worst case would be crap getting sucked in 'cos it's not going through the AF. You'd notice something wrong pretty quick, I reckon.
Casey: Can't imagine expanding hoses \"costing a psi or two\". I think they *might* increase lag in both spool-up and spool-down, though. Hardest ones to get to? Must be Murphy at work there! Would prefer to do without that noise, thank you very much.
Alf
Alf
2015 ND MT GT Crystal White Pearl Mica (pic to come)
PT wrote:I too had that happen with mine... Did make a good sound, but the first time it did I freaked not knowing what it was.
Loved that car!
Nice - yours must have been about the same year as mine was (late '89)although mine was the 4WS model. I still reckon that was the best car made by Mazda quality and equipment wise before the Japanese economic bubble burst and cost-cutting was introduced.
Mine was running 220hp ATW on 14psi with a high flow turbo, ECU reprogram (which also raised the over-boost fuel cut), mandrel 2.5" exhaust and increased fuel rail pressure.
- Alf
Well, had mine on the dyno today (Dyno Dynamics, 102kW vs stock SP @ 112 just before it, both measured in 5th gear).
That inlet pipe definitely ballooned out a bit, though nowhere near as much as the one in the picture that started all this.
Alf
Alf
- Sean
