Oil Leak
greasemeup
Re: Oil Leak
Postby greasemeup » Wed Jun 10, 2015 12:23 pm
FYI-
You can get a new sump plug with an "o-ring" half way up the thread, that apparently creates a seal.
Super Cheap has em.
Re: Oil Leak
Postby hks_kansei » Wed Jun 10, 2015 1:45 pm
MrNuts wrote:Quick update.
The oil leak is still there. Its leaking from the drain plug, not the oil filter.
I noticed that it only leaks if I take the car for a drive, which is almost every day.
Gonna order a new plug and new washers, then replace them after my exams. So in about 2-3 weeks.
The oil level is still around full, so hopefully the engine wont get damaged.
Oil thins as it heats, so the leak after driving would just be the oil getting thin enough to seep out. it's pretty normal for a leaky sump plug.
Engine won't get damaged unless you ignore it and let the oil drip out until it's low, since the difference between low and high on the dipstick is about 800ml, and the leak is presumably just a drip, you should be fine for a fair while.
greasemeup
Re: Oil Leak
Postby greasemeup » Fri Jun 12, 2015 2:25 pm
greasemeup wrote:FYI-
Super Cheap has em.
dd
MrNuts
Re: Oil Leak
Postby MrNuts » Tue Jun 16, 2015 10:33 pm
Super Cheap has em.
Yeap, saw some at repco a while ago. Might just grab those haha.
project.r.racing
Re: Oil Leak
Postby project.r.racing » Wed Jun 17, 2015 6:42 pm
MrNuts wrote:
project.r.racing wrote:mineral oil
I used Valvoline 5W-30 synthetic oil.
Then it should be amber, not brown when going in.
