NA8 flat spot 2800rpm
Re: NA8 flat spot 2800rpm
There's a post for you this week then in the technical guides area under the title "idle drop"
Jelzarhar did you end up changing the O2 sensor and if so did it make any difference?
NB SE, NA 1.8.
Yeah I did end up changing the O2 sensor and it made very little difference. It's the leads and ignition timing that really fixed it.
Yellow NA8 that makes lots of noise
