Looking for standard NB8B rwkw figure
mazmad
Re: Looking for standard NB8B rwkw figure
Postby mazmad » Fri Jan 11, 2013 3:04 pm
I hear you. :D
In reality it is more to do with how your torque curve changes, and how that suits your driving needs (road, track etc).
evil_weevil
Postby evil_weevil » Fri Jan 11, 2013 9:00 pm
slightly off topic...
but same dyno/different day
my r33 mate 255rwkw and MX5 75rwkw
haha
viewtopic.php?f=73&t=62834
mazmad
Postby mazmad » Sat Jan 12, 2013 5:20 am
And I don't think that difference is due to atmospheric changes :shock:
geofiz
Postby geofiz » Sat Jan 12, 2013 9:21 am
mazmad wrote:And I don't think that difference is due to atmospheric changes :shock:
I think you will find it is all to do with the atmospheric change. The R33 just has more atmospheres than the MX5 :P
NB8A - mostly stock for now
mazmad
Postby mazmad » Sat Jan 12, 2013 10:34 am
Quite right sir :D
mazmad
Postby mazmad » Mon Jan 14, 2013 1:53 pm
Post up a scan if you get it.
pcmx5
Postby pcmx5 » Mon Jan 14, 2013 1:57 pm
If it's a standard SE that is unbelievably high if it is RWKW .I am pretty sure standard SP's made around 114 RWKW at the Vic Club days over a 3 year period and they had around 30 more flywheel KW than the SE.
As always ,different dyno etc....
Peter.
Edit Just found Techno's records from 2003,4&5 Vic Club dyno days.
Peter.
Stock NA6's generally 58- 62 RWKW, NA8's 62-64 RWKW,NB8A's 66-69(a couple up around 72 but may have had mods,although Matty's made this power stock at another day)), NB8B's70-72, SP's 110-113. Some cars in each group made more but from my memory the quoted ranges are for standard cars averaged.
I know Chris Hoskin,s NB8B made70.3 in 2003 and about 74 later and then with exhaust and high flow cat got 82RWKW.All figures are from a Dyno Dynamics dyno
Postby 93_Clubman » Mon Jan 14, 2013 2:31 pm
nbse2 wrote:just had mine checked, mines an SE and it only registered 107kw which is pretty poor.
Presumably that's 107KW @ the rear wheels - if so that's good for a car that was rated at 121KW @ the flywheel. Deduct 10% for drive train losses gives you 109RWKW.
mazmad
Postby mazmad » Mon Jan 14, 2013 6:40 pm
10% loss is good given standard models lose 30%.
70rwkw yikes, bit grim isn't it.
Still, it's not what you've got but how you use it right? (been using that line on my wife for years.... :shock: )
Hjt
Postby Hjt » Mon Jan 14, 2013 7:00 pm
The SE should be around that figure, it was pretty piss weak in standard format.
Postby 93_Clubman » Tue Jan 15, 2013 1:03 am
mazmad wrote:10% loss is good given standard models lose 30%.
Indeed it's too good! Meant to say 20% approximation.
pcmx5
Postby pcmx5 » Tue Jan 15, 2013 5:05 pm
Techno's figures over almost 40 cars that were stock or lightly modified show a average loss of 30% plus,always assuming that the cars had the flywheel KW that mazda claimed in the first place!
Peter.
pcmx5
Peter.
Postby 93_Clubman » Wed Jan 16, 2013 10:36 am
pcmx5 wrote:Techno's figures over almost 40 cars that were stock or lightly modified show a average loss of 30% plus, always assuming that the cars had the flywheel KW that mazda claimed in the first place!
Pete, aware of Techno's figures, but I was going on Blackster etc figures which were SE specific.
