Taptaptaptaptaptaptap Noise?
- bear2230
Re: Taptaptaptaptaptaptap Noise?
Diagnosis............... Bent Rod........
What responsibility does the tuner have for this?
I’m not a happy camper.
- MINX
bear2230 wrote:Diagnosis............... Bent Rod........
Thats a bummer
When my car goes to the shop, i normally sign a form, agreeing to work to be done, and it includes a waiver for stuff like above.
Did you sign in/out your car?
I suspect you wont have any recourse with the tuner, unless he does you a good deal to help rebuild.
- Vehicle: Non MX-5
did you ask the tuner to wind up the boost?bear2230 wrote:Diagnosis............... Bent Rod........
- bear2230
project.r.racing wrote:did you ask the tuner to wind up the boost?bear2230 wrote:Diagnosis............... Bent Rod........
No I said I wanted 160rwkw 12psi he set it at 15 and 173rwkw and killed it.
I asked if he would help with the cost of the rebuild and he said no but will retune after it gets rebuilt (Hooray)
- NitroDann
Stock rods? Its not as simple as typing 12psi and 160rwkw into the ecu and getting it back, often the boost log shows a spike to 15psi and taper down to 12 psi. Did you specify 12psi at full power or not. Its really not as easy as saying he did 15psi now its dead.
- bear2230
NitroDann wrote:Stock rods? Its not as simple as typing 12psi and 160rwkw into the ecu and getting it back, often the boost log shows a spike to 15psi and taper down to 12 psi. Did you specify 12psi at full power or not. Its really not as easy as saying he did 15psi now its dead.
I know Dann it's nobody's fault except my own. I'm a dick, it's not the end of the world. I have bought a spare motor to rebuild anyway. Now I can rebuild the original moter which is better.
Anyone want to buy a VVT engine with only 87000km.
Car is being towed to Deckers Monday.
Bummer, Richard. Well, on the bright side, it'll come out bigger and stronger!
- Aussie Stig
- Stig
Bad luck Bearo.
- NitroDann
175rwkw on stock rods, it aint luck, its fate
- bear2230
I thought I would be the exception to the rule. Only being a street dríven car. Turns out, not so much.
What shitted me was I wasn't even driving it when it went. So no fun at all.
- NitroDann
If it takes X pressure to snap a twig, it doesnt matter if you apply that pressure one or repeatedly for 5 laps straight the twig will snap.
- Aussie Stig
- Stig
NitroDann wrote:If it takes X pressure to snap a twig, it doesnt matter if you apply that pressure one or repeatedly for 5 laps straight the twig will snap.
We all push our luck sometimes and sometimes the pooch gets screwed.
- bruce
- Vehicle: NA8 - Turbo
Sorry to hear that, but the description was terminal.
Onwards and upwards (maybe not the boost though)!
- bear2230
Carillo H-beams ordered. Let's see if we can bend them.
- Charlie Brown
bear2230 wrote:Carillo H-beams ordered. Let's see if we can bend them.
Ask Daniel to show you Matilda's Carillo big end bolts.
PS They don't like 10,000+ rpm down changes.
