Fitting the Commodore V6 S/C into the NA
wozzah1975
Re: Fitting the Commodore V6 S/C into the NA
Postby wozzah1975 » Thu Apr 19, 2012 11:47 pm
Charlie Brown wrote:
wozzah1975 wrote:
Caffeine wrote:
wozzah1975 wrote:I think a really good conversion for an early type car at the moment would be a duratec, 2 or 2.3 litre, or an FE3. If you want serious grunt turbo it.
If it were mine, I think I'd go with the duratec, had a look at a cylinder head a few weeks ago, lots of potential. The Caterham R500 superlight has this engine, making 263hp. RWD gearbox options available also. Bit of mucking around converting it I would suggest, but loads of potential.
Woz
Or just pull the running gear out of an NC :D Duratec 2L == NC MZR 2L
Sorry guys you're forgetting one real important point with the NC engine, turbo charging and RHD MX5s.
Im sure it would be the same in a NA as the NC, the turbo won't clear the steering shaft.
Pick another engine with the exhaust ports on the passenger side.
Are you laying out a challenge??? Whats wrong with a high mount? There's enough room for the OE Inlet manifold to curl up on a standard engine, and I reckon there would be someone around clever enough to plump one up :)
One thing is for sure, it would be alot nicer than fabbing bits for a V6 in there.......
Woz
wozzah1975
Postby wozzah1975 » Thu Apr 19, 2012 11:49 pm
Or you could supercharge it instead........ :P
Woz
bootz
Postby bootz » Fri Apr 20, 2012 12:06 am
I have always thought the Mazda mzr 23 turbo engine from the MPS would be a great conversion. :D
Postby NitroDann » Fri Apr 20, 2012 12:20 am
Ive already offered to build one.
Caffeine
Postby Caffeine » Fri Apr 20, 2012 10:19 am
wozzah1975 wrote:
Caffeine wrote:Or just pull the running gear out of an NC :D Duratec 2L == NC MZR 2L
Who said anything about turbocharging it?
An NA with the NC 2L engine, even stock, would be quite special :D
bootz
Postby bootz » Fri Apr 20, 2012 2:45 pm
NitroDann wrote:Ive already offered to build one.
Totally stock I could see it frying the tyres. :D
Charlie Brown
Postby Charlie Brown » Fri Apr 20, 2012 3:36 pm
wozzah1975 wrote:Or you could supercharge it instead........ :P
Woz
That's the smart way.
All the brains in Japan have only come up with a rear mounted turbo sitting in front of the last muffler, but if you have the answer I expect the all the RHD country's NC owners will be beating down your door to get one.
wozzah1975
Postby wozzah1975 » Fri Apr 20, 2012 4:07 pm
Woz
It's not in an NC engine bay..... however I don't think anything is an impossible task. I've seen turbo conversions engineered and put in very tight places.
Challenge layed out, who's got an NC as a donor car? :wink:
Woz
steverisingsun
Postby steverisingsun » Wed Sep 05, 2012 4:00 pm
Hi Guys thank you for your input.
Why a LY6?
At 171kw [flywheel] standard and with 250kw easily reached with no internal changes, why not!
The old LY6 has proven to be a far more reliable unit than the LS1. Mazda engines are fair at best when tuned to 250kw with weenie torque.
Cars in the US and A run low 12's/high 11's with the LS1 @ similar kws.
Handling with the conversions done in the states [inc Ford cast V8] shows to be fair, and this is just a street car, I have had lots of turbo cars and done many conversions [it's my job], this is something different.
As for fuel useage, could not care!
I have half stripped the donor Commodore, chasing up someone to redo the ECU to do away with the BSM and speedo requirement etc
I hope to get cracking soon, depending on the workshop work load
Steve
PaulF
Postby PaulF » Wed Sep 05, 2012 4:09 pm
Start a build thread. It might not be everyone's cup of tea but it's interesting and different.
steverisingsun
Postby steverisingsun » Wed Sep 05, 2012 4:31 pm
Will do Paul, trusty camera is around somewhere!
Thanks mate!
timk
Postby timk » Wed Sep 05, 2012 6:05 pm
I'm keen to see it Steve!
A friend of mine has recently put one of these engines into an old Hilux and it's such a great engine compared to the junk the car came with. Loads more power with much better economy!
steverisingsun
Postby steverisingsun » Sat Sep 08, 2012 4:45 pm
My choosing the L67 was due to it being a very compact engine, very reliable even when pushed well up power wise [we see units over 400,000k on original engines]. Weight is similar to the LS1 which has been fitted and worked well. The donor car cost me $1850 of which I have salvaged 1/2 to cars we were repairing. The poor MX5 goes ok, what budget would I need to get into the 12's with a Mazda engine? Using the commode diff, balance should be close to 50/50 as the yanks get close with the Winsor or LS1's. I can't find anyone who has tried this as most yankie 3.8's are FWD, so this is no suprise. Legality is not an issue. Minor mods will see 225kw with 300kw [flywheel] achieved around Oz with stock or near stock internals, thats cheap power!
Steve
Users browsing this forum: No registered users and 80 guests
