Maximum speed
Re: Maximum speed
Postby NitroDann » Thu Jun 09, 2011 2:47 pm
manga_blue wrote:Nevertheless you'd think that at those speeds you'd be able to ram more air in. Really, how hard does a turbo push compared to a 180kmh wind?
Dann, where are you drawing your air from?
2 part question, Firstly I have a sealed pretty well designed cowl intake. And some recent datalogs suggest that im making a little under 0.5 PSI of 'boost' at 50km/h.
Compared to a turbo, well patricks 1.06 at wakefield 'Casper', runs 15psi. Stock se is about 7.
The way you test air intake effectiveness.
Plug laptop into aftermarket computer, that has a map sensor (map sensors accurately measure pressure in 1 kpa increments).
Stop the car and turn the engine off at the exact piece of road you will take the reading. (protip, use a hill)
Take a reading of ambient air pressure.
Drive the car down the hill at speed.
Turn the engine off, note new pressure.
Total improvement is new minus old pressure.
Ie, I tested ambient at 98kpa, this may or may not have been perfect(nominal pressure is said to be 101, but depends on height above sea level, air temp etc) but im using the same measuring device so it doesnt matter.
Drive down hill, turn off engine, brake so im doing exactly 50kph, read datalog.
I found 101kpa at 50kmh, or 3kpa improvement, or 0.44 psi.
Aerodynamics are a subject with dimishing returns. it takes the square of the speed worth of power.
Ie, Double the speed takes 4 times the power, triple takes 9 times.
Im not sure if this means Ill get 4 times the pressure at 100kph, or 2psi. I need to do more tests, but its hard to roll at 100 while looking at a laptop without getting booked.
Hellmun wrote:
Weight is definitely a factor, use skydiving for a simple example. My force acting downwards is my mass * gravity. Therefore a change in my weight will change my total force exerted downwards. Since drag is a force(mass of air multiplied by the acceleration your body is exerting on it) by changing weight you will change the amount of negating force required to reach the same velocity. With the constant acceleration of gravity this actually means the higher weight increases your top speed. With a car in the horizontal plane the increased weight has a similar effect, it pushes the car down harder increasing vertical force, thereby increasing friction on the road and reducing the force available to overcome the aerodynamic force resisting in the horizontal plane. Being that the force is acting perpendicular it's simply a smaller factor because it's calculated at a tangent. Plus as mentioned, racetracks aren't really that big so the effect it has on reducing acceleration through drag really limits practical top speed. So I think quite relevant to discussion.
I agree fully. Though only due to increased rolling resistance as youve said but I feel that needs to be very clear.
Weight does not limit top speed. Acceleration is a rate of change, it measures how fast we can change speed. more weight equals more mass to accelerate slowing acceleration. Speed is purely Force VS Efficiency.
Its how hard you push vs how hard friction (including air friction, or air resistance) pushes back, when your friction caused by the tyres and air resistance equals your power you stop accelerating and reach terminal velocity.
but it does take 4 times the power to go double the speed.
TL;DR You need power and low friction for top speed, not low weight. the low weight only helps shorten the distance before you reach top speed.
When I hit 225 I was on a very long straight. Mind you the car would have gone faster, it was still pulling.
Ill also add I also have a non standard undertray.
Re: Maximum speed
Postby manga_blue » Thu Jun 09, 2011 10:01 pm
So much information! Thanks Paul, thanks Dann. I've got a s**tload of work on tonight so won't reply for a day or two.
Dann, there are worse things than speeding tickets. There has beeen one fatal accident in the Aust MX5 community that was related to data logging. I use an Innovate unit that I hook up to a netbook before I go for a drive and then don't touch or look at until I'm back home. I'd like to catch up with you at Wakefield sometime to discuss the intake stuff. It won't be the coming event in the first weekend of July though, for medical reasons I'll be running at Phillip Island instead. :wink:
Re: Maximum speed
Postby 93_Clubman » Fri Jun 10, 2011 12:54 am
Phil, not sure what you're allowed, but DIYing the visible scoop part of this
< http://www.autoexe.co.jp/products/ramai ... su/na.html > to complement the Loch Stewart/ MX5 Mania CAI might help - one of these might even provide a starting point: http://www.coolbreezescoop.com/servlet/StoreFront
Of course, you could go all out & fab a box with a scoop to drop in & sit behind the Loch Stewart/ MX5 Mania CAI in the cowl like the Autoexe.
You've probably also seen these at some stage:
viewtopic.php?f=28&t=35048
http://www.autospeed.com/cms/A_2162/article.html
http://www.autospeed.com/cms/A_2159/article.html
http://www.autospeed.com/cms/A_2160/article.html
Re: Maximum speed
Postby NitroDann » Fri Jun 10, 2011 1:42 am
Hey magnablue.
I was at the last wakefield day, im the young bloke who was their helping patrick bramston.
I asked you if we had met in another thread, you didnt repky, i figured you were frustrated with my 'crazy air con removing ways' as some others are and chose not to reply. Obviously not hahaha.
Would we have met last wfp day?
greenMachine
Re: Maximum speed
Postby greenMachine » Fri Jun 10, 2011 12:53 pm
93_Clubman wrote:Phil, not sure what you're allowed, but DIYing the visible scoop part of this
http://www.aus-cartalk.com/forum/viewto ... 28&t=35048
No need. The cowl is already a high pressure area, and I doubt that a scoop of this nature would add much. However it would be good to test it and see ...
:mrgreen:
Re: Maximum speed
Postby 93_Clubman » Fri Jun 10, 2011 1:21 pm
No need. The cowl is already a high pressure area, and I doubt that a scoop of this nature would add much. However it would be good to test it and see...
Some numbers for cowl & area above it:
http://forum.miata.net/vb/archive/index ... 19529.html
Re: Maximum speed
Postby NitroDann » Sun Jun 12, 2011 12:51 pm
Heres a pic of my intake.
As said it produces half a psi of 'boost' at 50km/h and manages air intake temps of under 15C on a day like today.
You can see the black heatshield, its actually polished underneath, just black there to avoid attention. and the pod filter airbox that its attached to has bolts and spacers, so the heatshield is always at least 10mm away and cant transfer heat.
The airbox also has heavy duty aluminium foil glued to it to stop radiant heat transfer.
Keen eyes will spot the red silastic sealing the whole thing.
gslender
Maximum speed
Postby gslender » Sun Jun 12, 2011 12:58 pm
Dan, how do ya measure the psi difference?
Re: Maximum speed
Postby NitroDann » Sun Jun 12, 2011 1:13 pm
Read the top post on this page.
greenMachine
Re: Maximum speed
Postby greenMachine » Sun Jun 12, 2011 11:22 pm
No undertray? Is that for a reason, or you just haven't got around to putting it back?
:mrgreen:
Re: Maximum speed
Postby NitroDann » Mon Jun 13, 2011 12:12 am
Took it off to install that fan.
The girlfriend wanted some parking practice (still a learner) so It came off to fit the fan.
My front ducting uses the bottom fan bolts so I need to get under and its a bit fidly to put a fan on. Remember I dont usually run a fan at all.
It hasnt been dríven since she drove it so thats how its sat in my garage.
And yeah before anyone says it, big cammy idle, light flywheel and 4 puck brass button isnt the best combo for an L plater to learn to park in.
Should have seen the look the guys in the r33 who pulled up gave her when they heard it hahahaha, 'hey bro.. What the hells in that thing...'
Re: Maximum speed
Postby NitroDann » Mon Jun 13, 2011 12:15 am
Ill add that it doesnt need that undertray to stay cool at all. It does seem to have more front grip at speed though.
Ive run no fan for what a month now? never a problem. Car cruises at 80-82 degrees if I dont block some of the radiator.
Re: Maximum speed
Postby manga_blue » Wed Jun 15, 2011 2:35 pm
Hellmun wrote:I'd still like to see a dyno chart comparison of your motor see how it's generating torque. The gearing isn't exotic (5 speed with 4.1) and I thought you had a stock shape muffler, undertray and hard-top which cover the main easy ways to mess with your aerodynamics. Being the easiest to check I'd start at the motor and then look at ride height compared to some other quicker N/A's, whether you've got sticky pads, worn sliders etc. So many small things can contribute....
I'm a loooong way from a dyno. Brakes have just come off for the regular regrease (they were fine anyway). Alignment is being redone today, but toe will stay at zero. Diff, gearbox and hardtop are beyond the budget and time available. It's all about doing the best with what I've got. It's running an OEM Mazda MAF but from earlier testing I know the Nissan MAF gives a bit more at the very top.
After Rascal's comments about how little difference main straight speed made to his laptimes I've actually raised the car a couple of cm to get the geometry working better. It's now at 324mm/330mm F/R (or 12.75"/13.0"). Basically I need to go back to classic theory which says get out of the corners quicker before big straights. Seems to work for Rascal ... but I'll still effectively max out at the PI and EC.
I'm still wondering whether the high pressure zone below the windscreen fails at 180kmh. Probably not but if I can find a cheap/free MAP sensor in the next few weeks I'll rig it into the cowl area in front of the driver and log it at those speeds.
BTW I drove track days and in inner city Melbourne for a year or two before I even noticed the fans didn't work. Finally boiled it idling on the dummy grid for 15mins at Calder on a stinking hot afternoon with the A/C on. Living in the bush now they're just surplus weight.
Re: Maximum speed
Postby NitroDann » Wed Jun 15, 2011 3:27 pm
My method for finding cowl pressure isnt very safe for me. Besides, 200 clicks with the engine off staring at a laptop would be hard to explain my way out of. Looks like its up to you.
StillIC
Re: Maximum speed
Postby StillIC » Sat Jun 18, 2011 12:11 am
Dann,
Power to overcome aerodynamic drag is a cubed root of power. Double the speed is 8 times the power, triple it is 27 times the power requirement.
Power = 0.5 * fluid density * coefficient * projected area * velocity ^3
Aero drag (measured as a force) is a square function of the speed:
Force = Power/velocity = 0.5 * fluid density * coefficient * projected area * velocity ^2
Scott
Users browsing this forum: Google [Bot] and 7 guests
