Adding a variable TPS to an NA6
- AmmoJammo
Re: Adding a variable TPS to an NA6
Whats the difference with bore size?
- NitroDann
Well.. And this is just from memory, the laser throttle body has a 5mm smaller throttle plate/bore, and a differently shaped throttle shaft.
- AmmoJammo
VL TPS doesn't fit the Familia B6t throttle body properly, as the shaft is too long.
I might get a VL throttle body, apparently the stock TB is 50mm, while the VL is 55mm, and should bolt straight on.
