1red5 wrote:when you say harmonic balancer, do they mean the crank pulley itself?
crank pulley, harmonic balancer, one & the same young padawan........I've seen them move before, it ain't a pretty thing
best of luck with it cshaks
AJ wrote:1red5 wrote:when you say harmonic balancer, do they mean the crank pulley itself?
crank pulley, harmonic balancer, one & the same young padawan........I've seen them move before, it ain't a pretty thing![]()
cshaks wrote:AJ wrote:1red5 wrote:when you say harmonic balancer, do they mean the crank pulley itself?
Hey AJ.... care to share any more????
I am hoping like hell that it is not something like a main bearing on the way out or something like that........ only 129K Km on the car too....!!
AJ wrote:cshaks wrote:AJ wrote:1red5 wrote:when you say harmonic balancer, do they mean the crank pulley itself?
nah, won't be a main bearing mate.......more likely a flogged out keyway that the pulley is held in position by, if it isn't too bad, it may be repairable, OR it may just be the pulley that is flogged, but if the keyway on the crank is fuxored, it means a replacement crankshaft
as a rule...............early NA's had this as a standard problem which was a hangover from the Ford/Lotus twin cam 1600 that Ford gave to Mazda to play with, I've never heard of any other model having the problem though
JBT wrote:Make sure they use a new pulley bolt or the same thing will happen again.
JBT wrote:That's a lot of advance.Be careful of detonation. I'd be using 98 RON fuel too.
