$2 mod for SP, 157kw atw
jules
Guitar Hero
Postby jules » Wed Nov 14, 2007 11:02 am
AJ wrote:
jules wrote:
Boags'MX5 wrote:
jules wrote:Oh, so the SE is huffing and puffing out 105kw already on the mod.
Wow.
Jules
:lol: :lol: :lol:
I peed a little. I love you Jules.
And I you, Boags :lol: :lol:
Jules
get a room :P
Can't. You and Wayne are performing "nut sack" cutting apparently :shock: :shock:
Jules
blackster
Postby blackster » Wed Nov 14, 2007 2:55 pm
Marty wrote:
blackster wrote:
Marty wrote:I did it and went from this before mod
to this after mod :shock:
Is there any particular reason why the pre run was done in 4th and the post run was done in 5th?
If your trying to get accurate power gain/loss figures, you would assume that the power runs would be done back to back and in the same gear.
I know they were in different gears and not back to back as I didn't have the chance but it is an indication of a noticable increase. Even without the dyno confirming more power it can easily be felt.
I dont doubt there is gain. Although, a 1 psi increase that gives 26rwkw irrelevant of inconsistent dyno factors is a little difficult to swallow.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Benny
Postby Benny » Wed Nov 14, 2007 4:50 pm
When I did this mod to my SP, the difference could be felt through the seat of the pants.
It just revved harder and the boost gauge went up by around 2 lbs, so it really does work.
On a club dyno day, my SP put out 152.2RWKw and standard SP's were putting out around 133-145 RWKw, so it must make a measurable difference.
Go ahead and splurge out for the $2.50.
If you're not happy with it, it's easy to reverse.
The only downside I noted was that the engine did jerk around when backing off the throttle while under boost, but SP's do that anyway and you learn to drive around it.
