Oxygen Sensor - problems
NMX516
Postby NMX516 » Thu Mar 26, 2009 10:51 pm
Okibi wrote:I took a gamble and got a Bosch 0 258 986 505-36Y.
I'll let you all know how it goes and if it makes any difference.
How'd you go with this Dave? Thinking I might be due for a newy on the SP...
Postby Okibi » Fri Mar 27, 2009 12:41 am
Yeah seems to be working well, I may even put a 4 wire in the NA6.
from the box
LS 05
0 258 986 505-36Y
NMX516
Postby NMX516 » Sat Mar 28, 2009 8:24 pm
thanks mate!
MX5CHIC
Postby MX5CHIC » Sun Mar 29, 2009 10:46 am
OK for those of us (me) not paying attention - Which Oxygen Sensor fits and works for an NB8A?
Is it the LS 05 / 0 258 986 505-36Y ?
Postby Okibi » Sun Mar 29, 2009 1:11 pm
Yes that's the one i've recently put in our NB8A, seems to be working fine.
Postby 93_Clubman » Tue Mar 31, 2009 12:21 pm
Okibi wrote:Bosch 0 258 003 550 (OEM ??)
Bosch 0 258 986 505 (The Manga choice) <-- 18watt heater (ground isolated case)
Bosch 0 258 986 507-36Y (93_Clubman and FastFreddy's choice) <--12 watt heater (ground isolated case)
IF the original IS the 0 258 003 550 then the 0 258 986 505 is the replacement listed.
In my case ('93 NA8) the 4 wire Bosch LS 07 0 258 986 507-36Y replaced the OEM 4 wire ND (Nippon Denso) 065500-9300 9N BPE8 MCA
