4k budget turbo build up for 1.8 nb how to?
lowmiata
Postby lowmiata » Tue Apr 10, 2007 11:24 pm
Fatty wrote:whaddaya mean the stock pump won't run them? you mean it won't be able to supply enough pressure to get me up to 150kw ? or it won't run them full stop ? coz it is running them fine right now (not boosted yet tho)
if you have fitted prog ECU
and have fitted the injectors yes they will work boosted or not
once you up the boost/duty cycle on the injectors the pump wont be able to supply the demand
the factory pump might beable to supply for 150kw but it would near the end of its usability and if something went wrong as its being maxed out it could be catistrophic
mines doing fine at 125 though
would be worth finding out if no one has its usability range.?
EVI15 1998 to 2008
Fatty
Postby Fatty » Tue Apr 10, 2007 11:29 pm
yeah thanks mate. this is what i thought as well - i would be right on the limit and it's probly not worth the risk of pushing the pump this far.
cheers for that.
ampz
Postby ampz » Wed Apr 11, 2007 12:20 pm
I think this would be helpful if you run the stock pump.
I had a piston go in a bluebird due to lean out issues and that was with a VL pump in it!
It's cheap insurance given it takes half a day to do.
Huh?
Fatty
Postby Fatty » Wed Apr 11, 2007 12:38 pm
ah yes, i already plan to do that. i have a spare fuel rail, a t-peice and some fuel line . just gotta get around to putting it all together.
sprx3
Postby sprx3 » Wed Apr 11, 2007 7:24 pm
hey guys quick update,
ive spoken to smb today & they do the top mount cast turbo manifold for the 1.8l, im sure lowmiata wont be too happy with the top mount :p but im sure i'll find a way to make it look all shiny & cool ;) oh & they will do it for 450 shipped :) so right on track
the guy also told me that they use sr20 s14/15 dump pipes for the gt28 so ebaying that brings a lot of cheap dump pipes like this
http://cgi.ebay.com.au/HKS-Style-Stainl ... dZViewItem
now for 100-150 im not sure it would be worth the stuff around of even trying to make one assuming they are good. what do you guys think of using the ebay dump pipes &/or has anyone used one as yet?
i know that i would have to change the front bit of my exhaust but would look at putting a 2.5\" system on it anyway :)
i can also get a hold of 550cc injectors off an fc rx7 will these be a little too big or will it still be tunable without rough idle & soforth with a large injector of its type?
oh & what do you guys normally runn for fuel pumps> internal or external? model numbers & prices would be great also ;)
lowmiata
Postby lowmiata » Wed Apr 11, 2007 8:18 pm
sprx3 wrote:hey guys quick update,
wont bother me mate as long as your happy thats the main thing!
using an sr dump pipe would save you the dollars maybe look for a custom one that is one piece to before the cat as it will hav a good bend on the back
the one on ebay you posted might point the exhaust to far back towards the firewall ratherer than in the down direction you would need to aim for
a custom one you could cut up and get a few free bends out of!
EVI15 1998 to 2008
The Pupat
Postby The Pupat » Thu Apr 12, 2007 2:01 pm
sprx3 wrote:oh & what do you guys normally runn for fuel pumps> internal or external? model numbers & prices would be great also ;)
I believe Cal put a Walbro 250lph internal fuel pump in his when he needed to upgrade. Said it wasn't too much drama to mount up.
Bevan
Postby Bevan » Thu Apr 12, 2007 5:10 pm
sprx3 wrote:the guy also told me that they use sr20 s14/15 dump pipes for the gt28 so ebaying that brings a lot of cheap dump pipes like this
Hang on a sec. The 200sx has a bottom mount manifold (so the turbo is mounted under the manifold). If you grab the same sort of turbo (T28) and top mount it, then use a 200sx dump pipe, it would be pointing straight into your bonnet! :?
sprx3
Postby sprx3 » Thu Apr 12, 2007 6:08 pm
thats a good point :idea:
maybe he was referring to his type of manifolds???
hmmmm will need to investigate a little further on that one :?
sprx3
Postby sprx3 » Thu Apr 12, 2007 11:40 pm
hey guys after all the info i can get on the emanage & auto tune & how it works & what i will need to set it up :)
cheers :)
Sean
Postby Sean » Thu Apr 12, 2007 11:47 pm
sprx3 wrote:i can also get a hold of 550cc injectors off an fc rx7 will these be a little too big or will it still be tunable without rough idle & soforth with a large injector of its type?
Good size to allow for future power incresae, but you'll have trouble getting them to idle well no matter what ECU you use, many blame the size, but it's more to do with thier different spray pattern.
