Build-up of the \"MX-7\" - Updated 19/5/07
Fatty
Postby Fatty » Fri Mar 30, 2007 10:08 pm
lil_mike wrote: the negative wire was grounding to the chassis :shock:
and what do you think the negative terminal on the battery is grounded to ?
but yeah, probably a good idea to ground it back to a common point to get rid of any ground potential differences... what is the correct term for that again?
marcusus
Postby marcusus » Sat Mar 31, 2007 11:03 am
:lol: Yes... slightly wrong choice of words :P
Duj
Postby Duj » Mon Apr 02, 2007 10:59 pm
Il send the stuff in the next coupla days,
Whats wrong with the oil cooler on it at the moment... :?
Currently driving an 01' GS300 2jz...
Postby orx626 » Thu Apr 05, 2007 5:06 pm
Mike, the only way forward here is to get Mazfix to go through the invoice with you, item by item and show you on the vehicle which is which.
adamjp
Postby adamjp » Sun Apr 08, 2007 8:08 pm
Your response will greatly define the relationship that you have with this company.
You may ask them for the old parts (like the battery). Technically it is yours not theirs. If they cannot produce it, you may choose to refuse to pay for the new one (particularly as you had just fitted one and can prove it from receipts and should have it fixed under warranty).
Irrespective, if the work they have done was NOT on the original quotation they prepared, you are not bound to pay for it, but you should give them the opportunity to return the car to the original condition. This should happen immediately, at their cost, and without damage to your vehicle. Not over the next week whilst they hold your car hostage or by literally ripping stuff of the car.
For my 2c worth, they have done some work that may or may not have been necessary, but they should have sought your approval FIRST. Ideally this request is accompanied by a firm quote, from them, to you.
However if you gave them instructions along the lines of 'make it roadworthy', they have a fairly strong case.
LESSON: Always be very specific when dealing with tradesmen, plumbers, mechanics, whatever.
Adam
AJ
Postby AJ » Thu Apr 12, 2007 5:40 pm
remember for next time mike: I MUST not mouth off at my mechanic until i've talked to him :wink: :lol:
as for the coughing & stalling, it's a rotary man, learn to live with it :lol: :mrgreen:
XMX5 Rogues
JBT
Postby JBT » Thu Apr 12, 2007 10:51 pm
It should run smoothly. There must be a problem (fuel/air/electrics......not necessarily in that order) causing the coughing and spluttering.
timk
Postby timk » Thu Apr 12, 2007 10:59 pm
See how it is after the tune, aftermarket management can take a lot of tweaking to get right.
Babalouie
godfather of saké
Postby Babalouie » Fri Apr 13, 2007 9:38 am
If it's not properly tuned yet, don't lean on the engine. Rotaries are very easy to pop when badly tuned.
Duj
Postby Duj » Wed Apr 18, 2007 6:32 pm
Did Mazfix compression test the motor?
The headlight relay is wired into the ignition,so when the ignition turns off so do the lights,i realised this after i got the car...
get some pics up.
Boags
Postby Boags » Wed Apr 18, 2007 9:26 pm
Duj wrote:get some pics up.
The man has a point. 8)
Duj
Postby Duj » Sat Apr 21, 2007 11:56 am
I replied to this the other day,this forum has some issues!
Unsure of which brand the front brakes are,but theyre still quite small so visit the hopperstoppers website and maybe look into an upgrade if youre gonna be doing warp speeds.
The clutch as far as i know is a heavy duty brass button.
I tracked down the guy who originally did the conversion (also called mike) but im unsure if Grandpa peter emu(who i got the car from) changed the clutch at all.
get pics up.
Duj
Postby Duj » Sun Apr 22, 2007 7:09 pm
What were u doing when u killed it? :shock:
Are u %100 its the gearbox?
Cars are doing 9's on those boxes so theyre pretty tough
I blew my diff when 1st got the car, but i swore it felt like the gearbox!
SuperMazdaKart
Postby SuperMazdaKart » Sun Apr 22, 2007 9:24 pm
the car really didn't like being away from Duj ey...
rent out a car trailer from a servo if you got a mate or relly with a reasonably capable vehicle
Boags
Postby Boags » Thu May 03, 2007 9:42 am
Excellent, keep us updated! :D
Boags
