Should my car be blowing black smoke?
Moggy
Postby Moggy » Sat Aug 26, 2006 9:04 am
Russellb wrote:
sab wrote:
Steve 818 wrote:MX's have two coolant temp sensors. The one at the back of the engine is for the temp guage, and the one at the thermostat housing is for the ECU.
Thanks Steve. Guage is working fine. Bonus with the ECU sensor being at the front and easier to access, provided that's the problem.....
NA6's have Three Sensor two in the back off the head One for gauge and one for ECU And then one on the Thermastat housing for the fan
NA8 had Two both in the back of the Head and none in the thermastat housing
They have two at the back! :shock:
I've been trying to work out why my coolant temp gauge hasn't worked since I changed the engine - all is finally revealed!! (Obviously I should have been looking at the wiring diagram a little closer.) Only problem is I only have one at the back now, I'll just have to wire it into the ecu temp sensor I guess...
Thanks! :P
Russellb
RIP Nov 2014
Postby Russellb » Sat Aug 26, 2006 9:24 am
Thanks! :P
Dont wire it to the ECU sensor :shock: The ECU will get incorrect reading
I have a pic some where of the two sensors will get them up later
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Moggy
Postby Moggy » Sat Aug 26, 2006 9:37 am
Thanks Russellb the pic should help a lot! :)
JBT
Postby JBT » Sat Aug 26, 2006 5:27 pm
1600 Engine
1800 Engine
Moggy
Postby Moggy » Sat Aug 26, 2006 9:44 pm
Thanks for the pics JBT. So the one I'm missing is the lower rh one on the 1.6. My engine looks like the lower photo, so I'll have to work out where to put a temp sensor - shouldn't be too hard. Thanks for your help folks! :D
JBT
Postby JBT » Sat Aug 26, 2006 10:46 pm
AFAIK, the temperature gauge sender is the thing just below the heater hose clamp on the 1800 engine photo. The other (large) plug on the water outlet housing is for the ECU connection.
Adam_NAclubman
Postby Adam_NAclubman » Sat Mar 31, 2007 2:34 pm
It's running rich...
Users browsing this forum: Bing [Bot] and 6 guests
