Engine Mounts
rascal
Re: Engine Mounts
Postby rascal » Wed Jul 28, 2021 2:33 pm
Roadrunner wrote:Maybe I should swing a spanner off everything in the engine bay just to double check though!
It's my standard process to do a spanner check before each meet ...
Has caught a few things that would have become issues on track....
StanTheMan
Re: Engine Mounts
Postby StanTheMan » Wed Jul 28, 2021 6:39 pm
yea that didn't happen on my 2nd engine change . learned my lesson....even though I should have learned that lesson years ago.
Roadrunner
coyotes after you
Re: Engine Mounts
Postby Roadrunner » Fri Jul 30, 2021 1:43 pm
On the topic of engine mounts, does anyone know if the bushing in a NitroDann hotside mount can be changed out to something softer? Is it a "standard" size bushing?
I like the ND mount as it incorporates a brace for the turbo manifold, but after driving a standard NB for a week, it would be nice to simmer down the SE vibrations if possible.
MeepMeep
ManiacLachy
Engaged
Re: Engine Mounts
Postby ManiacLachy » Fri Jul 30, 2021 1:55 pm
I believe AWR and Innovative (or something sounding like that) now make bigger (pyhysically) and softer (durrometer) poly bushes. These should reduce NVH compared to what was available at the time Dann made his mounts. Of course, this means a little more driveline movement, it's a trade-off, but it should still be stiffer than 2 rubber bushes.
PaulF
Re: Engine Mounts
Postby PaulF » Fri Jul 30, 2021 3:28 pm
I'm pretty sure Dann chose the poly bush to be the same size as one of the control arm bushes. Rear upper control arm rings a bell, but I'm not 100% sure. Theoretically I suppose you could press an OEM rubber control arm bush in.
Roadrunner
coyotes after you
Re: Engine Mounts
Postby Roadrunner » Fri Jul 30, 2021 4:36 pm
PaulF wrote:I'm pretty sure Dann chose the poly bush to be the same size as one of the control arm bushes. Rear upper control arm rings a bell, but I'm not 100% sure. Theoretically I suppose you could press an OEM rubber control arm bush in.
That's good to know. If I ever have the mount out for some reason I may just consider putting in a softer rated poly or IL Motorsports rubber. Though tbh I'll probably just get used to it again and forget about it till the dash starts rattling :lol:
MeepMeep
StuwieP
Re: Engine Mounts
Postby StuwieP » Thu Aug 12, 2021 6:51 pm
I'm confident that it's a standard suspension bush too but also can't assist with which one it is...
My NA6/SE build
Engine #1 RIP 04/07/2020
